Brake pads......opinions....
I need new ones.....don't fancy the standard ones......
Pagids seem to be the best but about double the price of mintex.......opinions please.......
Also looking for besr place to buy them from.
Cheers guys....
Jamie is thinking of Pagids.....
http://www.scottishelises.com/phpbb/vie ... hp?t=12020
Cheers guys....
- bertieduff
- bertieduff
Hmmm..can't find the link
Was around £200 for a full set IIRC, about 20% cheaper? Think 10 orders were required.
Generally, 42's for road & some track use, 14's for mostly track- (they need more heat than you'll get on the road)
/awaits correction/
/awaits correction/
- steve_weegie
bertieduff wrote:Hmmm..can't find the link![]()
/awaits correction/
14's eat discs if the pads are not up to temperature, so much so i need to replace discs and pads at the same time, every time
- steve_weegie
Depends on the discs i guess, but technically you're supposed to measure them with a micrometer thing. I run them until there's no grooves left on the disc surface then replace them.... They're eliseparts discs though and you wont be able to do the same with std drilled jobbies....
How many miles you got on the car now? I'll get around 10 to 15k from a set of discs, but thats running rs14 pads. You might get longer with normal pads though.
For road and occasional track use 1144 are best VFM.
For frequent track day use RS42 are more than good enough.
RS14 are overkill for anything less than racing and the associated budget.
SBS were OK, but I found them a little bit wooden compared to RS42 and I gather they are now not that much cheaper, so not sure SBS is worthwhile.
