Wheel and Tyre sizes
Titanium S1 111S (gla)
A friend has offered me a deal on a set of S2 wheels, does anybody know whether they will cross over onto my S1?
I haven’t heard of anybody doing a swap which makes me think that you can’t.
I have checked the sizes and they look very similar. Is there a difference in the stud pattern or some other issue I’m not thinking of like the effect on the suspension dynamics?
S1 S2
195 x 50 x 15 Front 195 x 50 x 16 Front
225 x 45 x 16.5 Rear 225 x 45 x 17 Rear
Cheers, Graham
S1 S2
Cheers, Graham
I think they may fit if you use geary's convertors http://www.eliseparts.com/shop/index.ph ... cts_id=219
Interesting, your quite right, those bolts are bast**ds. I had an MG F before the Elise which uses the same ones, why they can’t invest an extra couple of quid on proper machined ones I have no idea. I suppose that that kind of cheapness along with little joys like head gasket failure are there to remind us why all the volume British car manufacturers went t*ts up.
Still, gives us enthusiasts something to moan about / do on Sunday afternoons. I’m getting quite good a K-Series head gaskets although I’m not anxious to try one on the Elise.
Graham
Graham
I think the PCD is also different IIRC.
Long and short - they won't fit without major hassle. Plus, the geometery on the S1 is designed around the wheel/tyre combo. It's not massively different on the S2, but I believe there are detail changes at the rear. You may also have clearance issues.
Have never heard of anyone trying it, but best bloke to ask would probably be geary at Eliseparts...
