Front calipers on the back
Anyone done it, i know about the loss of handbrake etc but is it bolt on or is there more to it?
cheers
cheers
Motorsport K20 Elise
Re: Front calipers on the back
It's not bolt on, the caliper mountings are completely different.
You'll also need to do something about the brake balance as the piston surface areas are totally different.
All soluble problems with some research and an engineering workshop.
Fd
Fd
- steve_weegie
If you're looking to get more braking at the rear, you can machine out the std caliper to take a 40mm piston and get a good bit more rear pressure. Some info on seloc here. Its a mod I intend to do when i've got the cash for an AP upgrade at the front.
But in anwer to your question, nope I dont know anything about putting front calipers on the rear
What he said.fd wrote:It's not bolt on, the caliper mountings are completely different.
Fd
Dan@JPS
p.s. I wouldn't bother if I were you. Not really worth the effort.
Are these S2's really so heavy that the standard brakes are not good enoughsteve_weegie wrote:If you're looking to get more braking at the rear, you can machine out the std caliper to take a 40mm piston and get a good bit more rear pressure. Some info on seloc here. Its a mod I intend to do when i've got the cash for an AP upgrade at the front.
Fd
Can you lock your brakes in the dry with your current set up? Bet you can. If so you have enough brake power! You can't get any more braking power onto the road. Stickyer rubber and better suspension setup will enable you to, if its fading brakes, then that is a different problem that will not really be solved with bigger calipers.
Looking to put 4 pots on the front so just thought abotu beefing up the rears as well, if it involves lots of buggering about then i wont bother, as for locking up, the fronts yeah easy, the rears, dont think so
- steve_weegie
http://wiki.seloc.org/a/Brembo_Caliper
As I say, its worth considering for the little cash outlay....
Something seriously wrong with your brakes then . . .foz01 wrote:as for locking up, the fronts yeah easy, the rears, dont think so
Fd
- steve_weegie
Aye, bias...fd wrote:Something seriously wrong with your brakes then . . .foz01 wrote:as for locking up, the fronts yeah easy, the rears, dont think so
Fd
Was dont think so as in i am not aware of locking up the rears, not as in, "i dont think so lolfd wrote:Something seriously wrong with your brakes then . . .foz01 wrote:as for locking up, the fronts yeah easy, the rears, dont think so
Fd
If that makes sense!?
Ok, will look into it- rears are looking pretty sorry for themselves i have to say- could do with a rebuild and if was doing that would get the cylinder bored outsteve_weegie wrote:http://wiki.seloc.org/a/Brembo_Caliper
- steve_weegie
Aye, the graph down the page speaks volumes when tested on the viper. My plan was to machine out to 40mm and see how the balance was after that. If necessary, an AP bias valve could be added to move it about a bit if needed.
Alternativly you could just move the bias forward with a bit of left foot braking
So . . . y'all think the bias is wrong on a standard Elise then ?
On track if I put my foot on the clutch when breaking on the ragged edge the rears will lock . . . I stop this by leaving it in gear . . . as you're supposed to . . . any more rear bias and it'd be very difficult to brake hard enough as the rears would lock far too easily . . .
You are driving Elises right ?
Sure if you change the fronts then you'll screw up the bias . . . but stock the bias is pretty much spot on . . . IMHO . . . and in thousands of laps of KH I've never needed any better brakes . . .
apart from in the caterham where I can destroy the brakes in about 30 minutes . . .
Fd
Fd
- steve_weegie
Ah no sir eee, I only think the bias would need adjusted if i was fitting big AP rotors at the front
I need the bigger AP rotors, as i buckeled the eliseparts bells after an enthusiastic session... But not everybody brakes as late as me
Some air scoops for the drums might help? Slowing down is also another optionfd wrote: and in thousands of laps of KH I've never needed any better brakes . . .apart from in the caterham where I can destroy the brakes in about 30 minutes . . .
