Tightening wheel nuts by hand , Torque ?
I understand there is meant to be a certain torque wheel nuts are set too but is this really essential ?
i dont have a torque wrench , i am gonna take the wheels off today , can I simply nip them up tight tight and all will be fine ?
thanks.
thanks.
Re: Tightening wheel nuts by hand , Torque ?
105 is the correct torque, some people do (I am one) and some don't.......not herad of any wheels falling off........yet!
- BiggestNizzy
do not "nip" them up I use a 24" breaking bar and I tighten until I lift the wheel off the ground, probably to tight but If I ever have to change the wheel again I will use the same breaking bar as the elise doesn't have a sh1t oem wheel brace.
to sum up tight
to sum up tight
Studs on my S1 (yours uses bolts and to a higher torque) did end up snapping (on a run) after years of just cranking them up and saying "that'll do" Don't imagine that'll be an issue with the bolts on the Exige - just be careful of stripping those facking splined nuts.
Screwfix and Machine Mart do cheapy torque wrenches for bobbins (under £15 IIRC) if you're considering having the wheels off and on a fair bit (know how you polishers like everything clean
) Needless to say, one lives in my boot now...
Check your studs - seriously. S1s are something like 85lb/ft which isn't all that tight and as I said, I've had two studs shear after years of yanking them up with a breaker bar...BiggestNizzy wrote:do not "nip" them up I use a 24" breaking bar and I tighten until I lift the wheel off the ground, probably to tight but If I ever have to change the wheel again I will use the same breaking bar as the elise doesn't have a sh1t oem wheel brace.
to sum up tight
At the very least, you'll have taken all the stretch out them, so they won't lock up properly...
wheel shouldnt really be on/off too much , but its is the spring clean this time
Think that concerns me is that i read in previous thread while back that the annoy wobble in steering wheel at 85-95 tuts can sometimes be caused by overtightening of nuts ?
Pagids to clean???j33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
I'm sure there is a joke there too!j33ama wrote:Think that concerns me is that i read in previous thread while back that the annoy wobble in steering wheel at 85-95 tuts can sometimes be caused by overtightening of nuts ?
If you're at all concerned, would make sense to trundle into Gt Western Road and grab a torque wrench out of Machine Mart for the price of a curryj33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
meatball wrote:Pagids to clean???j33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
yeah gonna drive up just now , worth going to machine mart ? much cheaper ?Shug wrote:If you're at all concerned, would make sense to trundle into Gt Western Road and grab a torque wrench out of Machine Mart for the price of a curryj33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
Okay one querie solved I have another 2 ...........see technical page
Cheaper than? Halfords have a pro one, which is pretty decent, but also about £50 last time I looked. For wheel bolts, the MM one will do the trick and you won't be too pissed off if it gets left somewhere.j33ama wrote:yeah gonna drive up just now , worth going to machine mart ? much cheaper ?Shug wrote:If you're at all concerned, would make sense to trundle into Gt Western Road and grab a torque wrench out of Machine Mart for the price of a curryj33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
MM it is then . Thanks
pagids may well get painted today also ............
Orange?????j33ama wrote:meatball wrote:Pagids to clean???j33ama wrote:wheel shouldnt really be on/off too much , but its is the spring clean this time![]()
I think you need to get out more.......
Not telling .
