slight misfire under load
Post by Shug » Fri Mar 28, 2008 12:32 pm
Had an interesting one last night on a wee run to pick up a kilt. On highish load but low revs the car started to miss. Fine at reasonable load (under 1/2 throttle) didn't happen on lightish load as I picked up revs.
Switched it off, picked up the kilt and it'd sorted itself for the drive home. Car just got up to temp for maybe 5 minutes both ways, but problem didn't repeat on the way back.
Perhaps starting signs of a coil pack on the way out? (S1 VVC engine, so 2 coils) Had a wiring issue a while ago where the plug to one coil was a bit dodgy, but they've all been cleaned up and it's been fine since.
Don't think it'll be water in the wells, as they'd have dried out as it got to temp, not started acting up.
steve_weegie
Re: slight misfire under load
Post by steve_weegie » Fri Mar 28, 2008 12:45 pm
Yup, stinks of HT to me.... I had a similar problem a while back & it turned out that it was the HT fly leads from the coil packs that had packed up, rather than the coil packs themselves. Found both for a smidge more than a tenner at some local motor factor, and the car's been fine ever since :thumbsup
Post by Rich H » Fri Mar 28, 2008 1:24 pm
Mine did that when an HT was not fully plugged in. :thumbsup
Post by Shug » Fri Mar 28, 2008 2:14 pm
I'll pull em and clean them up then. Could probaby use a new set, in all honesty.
graeme
Post by graeme » Fri Mar 28, 2008 2:35 pm
Don't get Magnecor Reds. Waste of money, too fat to fit under the plug cover neatly, and a poor seal round plug wells.
VXJON
An Equal Opportunities Lover
Post by VXJON » Fri Mar 28, 2008 3:37 pm
Shug wrote:Had an interesting one last night on a wee run to pick up a kilt.
Knew Id forgotten about something :oops:
Post by Rich H » Fri Mar 28, 2008 6:00 pm
Bosch efforts form Halfords :thumbsup
