Heater
craigs135s
Heater
Post by craigs135s » Sat Mar 29, 2008 11:31 pm
Tonight when coming home my heater started to make a vibrating noise when it was on full. Any ideas why this would be?
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
steve_weegie
Re: Heater
Post by steve_weegie » Sun Mar 30, 2008 1:02 am
It's knackered? :leave
Could be the blower spindle off balance due to crud or a worn out bearing... Could be that its not secured properly and is vibrating in its housing too I guess... Dont know really, but the blower is the place i'd start looking :thumbsup
Re: Heater
Post by r055 » Sun Mar 30, 2008 11:15 am
from time to time the fan on mine sounds like its rubbing against the casing, me and ali looked at it the other day - looks a bit corroded down there.
does it sound like that? ie does the noise get faster as you put the fan up higher?
craigs135s
Re: Heater
Post by craigs135s » Sun Mar 30, 2008 11:29 am
Yes when the fan is on the second setting its fine but when its on the 3rd is noisey. What did Ali suggest?
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Re: Heater
Post by r055 » Sun Mar 30, 2008 11:38 am
im not particularly bothered with the noise - its just a feature!
but he reckons thats where the burning smell is coming from... new heater matrix soon i think :roll:
Re: Heater
Post by r055 » Sun Mar 30, 2008 11:40 am
i dont know what the access is like for the exige, but id take off the silver hose which is connected to the fan and have a look to see if anything is touching it.
steve_weegie
Re: Heater
Post by steve_weegie » Sun Mar 30, 2008 11:40 am
My guess would be the blower spindle bearing is worn out, causing havoc for the motor bushes & hence the burning smell...
craigs135s
Re: Heater
Post by craigs135s » Sun Mar 30, 2008 11:42 am
steve_weegie wrote:My guess would be the blower spindle bearing is worn out, causing havoc for the motor bushes & hence the burning smell...
Steve is this an easy fix?
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
steve_weegie
Re: Heater
Post by steve_weegie » Mon Mar 31, 2008 12:47 am
Probably a new enclosure from lotus, unless you can source a new blower and modify the housing to take it :?
As for how easy it is to get to....well.....
lotus service manual wrote:
1. Remove the front clamshell
2. Remove the trunking between fan blower and distribution unit. Remove washer bottle
3. Drain coolant and disconnect the two water hoses from the heater unit
4. Disconnect the electrical harness from the resistor block and fan motor.
5 Release the two M6 fixings securing the heater unit to the chassis footwell crossmember and withdraw the unit from the chassis.
Not exactly a piece of cake :shock: :shock: :shock:
