Brake Problem - Now how to bleed / change fluid
Post by Sanjøy » Mon Mar 06, 2006 1:59 pm
After a full day at East fortune I noticed the brake travel was more than normal. This culminated with a distinct lack of braking at the end of the straight.Did a warm down then came in.
The front left calliper was making a loud creaking noise when depressed. Al form MMC had a look but nothing was visible and no fluid leaks.
Any initial thoughts before I get it in to the garage ?
SP
Post by mac » Mon Mar 06, 2006 2:24 pm
I'd go with moisture in the fluid, which boils under hard use and causes a vapour lock.
Time to change fluid IMHO.
Ask DDtB :D
Lawrence
Post by Lawrence » Mon Mar 06, 2006 2:49 pm
Yup
change the fluid first
Post by Sanjøy » Thu Mar 09, 2006 9:29 am
Anyone got an online guide ?
Post by Sanjøy » Thu Mar 09, 2006 10:53 am
Hmm worth putting on braided hoses while I do it ?
Post by mac » Thu Mar 09, 2006 11:10 am
Braided hoses are a good idea.
But if you need an on-line guide I don't think you should be playing around with brakes :shock:
Post by Rich H » Thu Mar 09, 2006 5:02 pm
I used one..... :roll:
It's only a hydraulic system, just ensure it doesn't leak and all the air is out.
Fcuk it up and you'll know pretty quickly though.... :shock: :shock: :shock:
ewanrw
Post by ewanrw » Thu Mar 09, 2006 5:54 pm
RICHARDHUMBLE wrote: Fcuk it up and you'll know pretty quickly though.... :shock: :shock: :shock:
subtle :wink:
Post by Rich H » Thu Mar 09, 2006 5:58 pm
:wink:
Post by Sanjøy » Sat Mar 18, 2006 7:28 pm
Anyone fancy a spanners day next week? Need to change brake fluid, possibly fit braided hoses and change heater matrix.
Post by Victor Meldrew » Sun Mar 19, 2006 2:10 am
Lawrence wrote:Yup
After having brake fade and a seriously spongy pedal for several miles, I will be flushing through the brakes on my car.
Looking for advice on the make of brake fluid.. i.e. do I just walk into halfords and buy the most expensive or is it better to order competition fluid from demon tweeks? There has been so much talk on fluid I get confused reading the threads on the yahoo site and on here.
The_Rossatron
Post by The_Rossatron » Sun Mar 19, 2006 3:13 am
I think I could do with changin mine too :S
http://www.allflashnocash.com
Post by mac » Mon Mar 20, 2006 9:03 pm
Fluid,
you can put exotic stuff in if you really want but most use Castol Super DOT 4 - about £10 per litre from Halfords - you need about 1l but get 2 if it's your only car!
Post by Sanjøy » Wed Mar 22, 2006 2:21 pm
So anyone fancy changing together ? :shock: As need a brake pedal man.
Post by Rich H » Wed Mar 22, 2006 6:33 pm
Sanjoy wrote:So anyone fancy changing together ? :shock: As need a brake pedal man.
I found I didn't need one, use an easy bleed and just hop in and push it yourself :wink: Beware of too much movement as (I think someone said on here) you can hit any corrosion at the end of the master cylinder.
I have said it before but:
PRESSURE TEST THE EAZIBLEED BEFORE FILLING IT UP WITH FLUID!
Or you'll have a front compartment full of fluid, like me :roll:
HTH
