Ran the car yesterday and today. 05 111R with 5k on her. Washed her tonight and then went for a run but the hand brake light stayed on. It was dim compared to when the hand brake is on but stayed on none the less. Is it pads? Water in the system somewhere? Was braking fine with no fading etc.
Thanks.
Stuart.
Hand brake light.
- transglobal
Hand brake light.
Elise 111R
BMW 530d M Sport
Triumph 955i RS
BMW 530d M Sport
Triumph 955i RS
Re: Hand brake light.
Did the light go out when you pressed the brake pedal?
- transglobal
No, it stayed on all the time. When I stopped and applied the hand brake it got brighter but when I put the hand brake off it stayed on but a little less bright. The only thing I did before this was wash the car. What do you reckon?
I''ll check it in the morning again but thought it strange.
Stuart.
Stuart.
Elise 111R
BMW 530d M Sport
Triumph 955i RS
BMW 530d M Sport
Triumph 955i RS
I'd give Robin a shout - or wait for him to come along and tell you what it could be!!
Try pushing the lever down - seriously!
The switch for the light is below the lever - if you put a finger in the hole where the lever goes up and down - you'll be able to feel it!
(I'm sure I've left that open for the smut kings to edit appropriately!
Caterham Roadsport 190
Tesla Model 3 LR RWD
- Matelotman
I concur the sticky / duff switch theory - had that problem on other cars before
- transglobal
Found the hole, found the switch, had a fiddle and pushed down on the lever but to no avail. I reckon its the sticky switch / faulty switch issue. Nothing to worry about then but I was just making sure that I wasn't missing anything more serious.
Thanks for your help.
Stuart.
Stuart.
Elise 111R
BMW 530d M Sport
Triumph 955i RS
BMW 530d M Sport
Triumph 955i RS
