2nd Gear Squeek
Re: 2nd Gear Squeek
Yep, take the plastic gearlever cover off, and let the mouse out.
Re: 2nd Gear Squeek
It'll be the plastic cover plate at the top rubbing....
Not you can do apart from maybe spray some DW40 down there or wait for it to wear down
Re: 2nd Gear Squeek
Thanks for that, got a pm from KIRK, he thinks it might be gear linkage needing a bit of lub, getting it serviced soon so will leave it upto the mech to sort.X7LDA wrote:It'll be the plastic cover plate at the top rubbing....
Elise 111R
