OK. It had a service a couple of weeks ago and following the service the temperature gauge was under-reading - showing about 78 degrees and previously it had always sat at 84 - rock solid. Asked on the Yahoo group and was advised not to worry too much because it was within tolerances. I decided that as it is going back to the garage soon to get new brakes I'd wait until then before I did anything about it (and I've been dead busy and I'm lazy). It would seem this may have been a mistake.
Suzy has been driving it for the past week but I've brought it to work today and the temp is not climbing over 74 and occasionally is dipping to no temp showing. Stopped to have a look and it has used some water (down to min on the expansion tank) and there is, what I am loath to describe as mayonnaise but prefer to refer to as gunk on the inside of the oil filler cap. It is running fine though, heaters are still working I've not noticed any steam.
So I need advice, obviously it will go back to the garage Monday to see what they say but if it is HGF what am I looking at?
What do i need to do to fix it? (I know there are *better* gaskets available. Better bolts? Didn't I read about a fix somewhere?)
If the head has to come off can I find a silver lining? Are there any upgrades I should/can do whilst the head is off (that *don't* affect reliability)?
Any advice would be more than welcome.
'03 S2 111S. 25000 miles. Always warmed up properly. Not right.
