Steering Rack
- tuscan_thunder
- BiggestNizzy
Re: Steering Rack
Jack up the front of the car (both sides) and give the wheels a shake and feel for play in the rack
- tuscan_thunder
Re: Steering Rack
will do.
the steering, this weekend, felt like it was sometimes 'sticky' that when turning the wheel there were moments of increased resistance.
I was on roads I'm on all the time and tyre pressures were normal.
Mair throttle, less brake
Re: Steering Rack
If it's at exactly the same point, you could have a damaged tooth on the rack or the pinion, jamming it up a bit.tuscan_thunder wrote:will do.
- tuscan_thunder
Re: Steering Rack
it's more like tramlining really, like the pressures are low and it's pulling. As i turn the wheel, it does the usual Elise delicacy thing then hits what I can best describe as 'stiction' just occasionally - not at any specific steering input: sometimes 1/8th of a turn, sometimes at 1/4 etc.
Geo is maybe just out (it 'looks' right.....) but it's a different feeling to geo/toe setting being out
Re: Steering Rack
Weird, might be something floating about inside the rack (like bits of a broken end-cup possibly) and getting in the teeth... Definately jack it up and check for play as if anything's broken in there, it'll show up with that - might also be worth turning the rack from wheels with no load on it - will show up the stiff points. Not a major hassle to re-build a rack.tuscan_thunder wrote:it's more like tramlining really, like the pressures are low and it's pulling. As i turn the wheel, it does the usual Elise delicacy thing then hits what I can best describe as 'stiction' just occasionally - not at any specific steering input: sometimes 1/8th of a turn, sometimes at 1/4 etc.
Re: Steering Rack
Knackered ball joint(s)?
