Paolo
by Paolo » Wed May 21, 2008 6:36 pm
...fancy having a listen to the rattle I have?? MMC had a look at it a few weeks ago (when it was being serviced) and replaced a worn droplink. Still getting a very annoying rattle from the drivers footwell going over small bumps. It might not be anything too serious but I could do with some guidance on what to rule out before I take the trip through to Edinburgh (again). Even a "it's nowt to worry about" would make me feel a little bit better.
It's a yota 111R and I'm in Paisley.
Paul
PS. Could be worth a free wash and wax...
s29ttc
by s29ttc » Wed May 21, 2008 6:41 pm
jack the car up get under it and have a look about look for anything thats loose. RAttle bits and bobs about and you might find whats causing it hence problem solved.
1999 S1 Elise 111S - Fun Spec
Jamie84
by Jamie84 » Wed May 21, 2008 6:46 pm
I have the same rattle/knocking I think your on about .
I used to worry about every little noise with my car , now Ive learned not to care . Once it stops moving or loosing fluids then ill call ali
Paolo
by Paolo » Wed May 21, 2008 7:09 pm
s29ttc wrote:jack the car up get under it and have a look about look for anything thats loose. RAttle bits and bobs about and you might find whats causing it hence problem solved.
Great. Thanks.
steve_weegie
by steve_weegie » Wed May 21, 2008 7:10 pm
could be somthing as simple as the return spring on the accelerator mech? dunno, buy a louder exhaust
steve_weegie
by steve_weegie » Wed May 21, 2008 7:11 pm
ps, if you want to wash and wax my car, i'll have a look
s29ttc
by s29ttc » Wed May 21, 2008 7:15 pm
PaoloMcFoulo wrote:s29ttc wrote:jack the car up get under it and have a look about look for anything thats loose. RAttle bits and bobs about and you might find whats causing it hence problem solved.
Great. Thanks.
No probs, I know its not the best bit of advice but I do not have any technical knowledge of cars oil change and changing a set of brake pads (the correct way round
)are about as far as my knowledge goes but if its knocking only when your going over bumps you would think its something loose and you might by luck see it or if you shake something and it rattles you know thats probs where noise is coming from. Least I tried ........
Paolo
by Paolo » Wed May 21, 2008 7:21 pm
s29ttc wrote:PaoloMcFoulo wrote:s29ttc wrote:jack the car up get under it and have a look about look for anything thats loose. RAttle bits and bobs about and you might find whats causing it hence problem solved.
Great. Thanks.
...only trouble is, there ain't much to see under a Lotus.
Paolo
by Paolo » Wed May 21, 2008 7:22 pm
Jamie84 wrote:I have the same rattle/knocking I think your on about .
Yep, should probably adopt the same philosophy!!
s29ttc
by s29ttc » Wed May 21, 2008 7:25 pm
Ahhhhh good point! hahaha mid engine. Worth a wee look anyways. I know other cars are bad for heat shields rattling but if it is only over small bumps you would think mabye an exhaust rubber or something, this being mid engined though I have no knowledge of what the exhaust is like. Probs be something stupid dangling about or a bit loose and probs nothing to worry about, just have a look and see what you can see wont do any harm.
s29ttc
by s29ttc » Wed May 21, 2008 7:30 pm
Just had a thought may be a stupid one but here it goes, see if you have just had it serviced you would have an oil change. I am sure someone said there is a cover on the bottom which they would have took off to get to the sump I take it. If so might just be one of the bolts loose and the cover rattling over bumps..........
Long shot.........
by r055 » Wed May 21, 2008 7:42 pm
PaoloMcFoulo wrote:...fancy having a listen to the rattle I have?? MMC had a look at it a few weeks ago (when it was being serviced) and replaced a worn droplink. Still getting a very annoying rattle from the drivers footwell going over small bumps. It might not be anything too serious but I could do with some guidance on what to rule out before I take the trip through to Edinburgh (again). Even a "it's nowt to worry about" would make me feel a little bit better.
Paul
Paulo,
could be a case of TADTS for elises - its usually when clunking and rattles stop that you should worry!
try jacking up the right hand side and see if theres any play in the wheel - i.e. push and pull the wheel as if moving the wheels to turn left and right putting your hands on the 3 and 6 oclock positions. can you feel a discreet knocking vibration through the wheel when you do this?
what age is the car?
does the noise stop at all when you are braking?
im no expert, but drop me a PM if you want me to have a quik look at it.
by Lazydonkey » Wed May 21, 2008 10:00 pm
steve_weegie wrote:ps, if you want to wash and wax my car, i'll have a look
Paul - word of advice. Don't ever accept this invite. Ever.
We used an entire spray thing of wheel cleaner on his wheels and they were still manky.
Oh and im no expert but i think it's probably a TADT - you should come out in my car. it will make you feel so much better about how quiet your suspension is
Paolo
by Paolo » Wed May 21, 2008 10:05 pm
...someone's gonna have to explain TADT
steve_weegie
by steve_weegie » Wed May 21, 2008 10:35 pm
PaoloMcFoulo wrote:...someone's gonna have to explain TADT
They All Do That
TADTS is then lotus are telling you it, as they append the Sir to the end
