Brake pads
Brake pads
Where is cheapest to get Mintex 1144 pads?
- Lazydonkey
Re: Brake pads
camskill
Re: Brake pads
Caterham Roadsport 190
Tesla Model 3 LR RWD
Re: Brake pads
Another vote for camskill, never had any problems with deliveryRDH wrote:Or JRT AutomotiveLazydonkey wrote:camskill
http://shop.instant-shop.com/JRT-Automo ... 50649.html
http://www.camskill.co.uk/products.php? ... s1210p4104
Re: Brake pads
Cheers, was going to order from Motorsport World in Strathaven, they were cheaper as no postage. Or so I thought, they want £8.00 postage even if I collect !!.
Any idea how OMP pads compare with 1144, they are considerably cheaper and seem to get a decent write up on SELOC wiki.
I take it vx pads ( Camskill) are the same as Elise?
Re: Brake pads
Same pads
Re: Brake pads
I had OMP's on another car, not that good tbh. Not sure I'd bother with the 1144's for the elise either. Mine had to be filed down to fit, I'd go for SBS pads the next time if not streching to pagids. Never had a problem with MSW in the past though, they're usually 1st class to deal with.j2 lot wrote:Cheers, was going to order from Motorsport World in Strathaven, they were cheaper as no postage. Or so I thought, they want £8.00 postage even if I collect !!. Think they have just lost any business they may have got from me.
Re: Brake pads
Bit of a drift:
My rear pads are not worn evenly, is that normal?
There is twice as much left on the outer pads
I take it that the slide pins are stuck or sticky?
Re: Brake pads
TADTS
Re: Brake pads
Cool.
Just asked Stu for a set of discs for the front, going to put the fornts on the rear (they are newer and less pitted) then its new pads all round, probably SBS pro? We'll see how far I can stretch the budget. Probably end up with 4 rebuild kits while I'm there too...
Like the bloody porker, started with rust bubble, ended up with a huge repair to weld in and a rattle can respray by installments, I might go and buy a Civic...Not
Sorry for the continuing hijack but is it worth changing the pads with the disc or is it better to run the disc in first on the old pads?
TIa
TIa
Re: Brake pads
Change the pads with the disc, unless you're as pikey as me. Means the disc has an even wear pattern from the start. If you're getting pads anyway, you might as well just go with them from the get go.
Re: Brake pads
I'll probably go with the pikey option then,to even out the cash flow (Or I couldbuy the pads on credit card... hmmm...
The Porker needs tax, the Elise needs a service and tax in Aug and I have 4 wheels to refurb & straighten / buy... SWMBO will kill me
Ta
Ta
Re: Brake pads
In the pursuit of ultimate pikeyness I'll fit the outer pads on the inside too make them last even longer
- BiggestNizzy
Re: Brake pads
Rich H wrote:In the pursuit of ultimate pikeyness I'll fit the outer pads on the inside too make them last even longer
- craigs135s
Re: Brake pads
Where do you get SBS pads?
C
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
