Tyre-Pressure-Temperature-Monitor
Post by Victor Meldrew » Tue Jul 01, 2008 11:52 pm
Anyone else think this might be a nice little track gadget.......
http://cgi.ebay.co.uk/Tyre-Pressure-Tem ... 20Features
tenkfeet
Re: Tyre-Pressure-Temperature-Monitor
Post by tenkfeet » Wed Jul 02, 2008 12:55 am
A tyre pressure gauge and pyrometer is much cheaper and probably more reliable . If I am not mistaken you want to know tyre temperature across the tyre surface .
I need convincing .
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Post by BiggestNizzy » Wed Jul 02, 2008 1:39 am
tenkfeet wrote:A tyre pressure gauge and pyrometer is much cheaper and probably more reliable . If I am not mistaken you want to know tyre temperature across the tyre surface .
thinfourth
Post by thinfourth » Wed Jul 02, 2008 7:19 am
Air temp is pretty irrelevant you want to know temps across the tyre surface as in inside edge, middle and outer edge this gives you a clue as to how your tyre is gripping the track.
If your inside edge is way hotter then the outside edge then for some reason the inside is doing more work then the rest of the tyre
Post by BiggestNizzy » Wed Jul 02, 2008 9:24 am
with enough data gleamed from this you can start adjusting camber/pressures to suit different tracks so that you get an even temp across the tyre, this shows that all the tyre is being used in the most efficent manor.
Post by Victor Meldrew » Tue Jul 08, 2008 12:44 am
Check out the latest TRACK AND RACE CARS for a write up of TPM systems...
for £100.... if it helps me get the tires working properly and hypotheticaly lasting longer then its worth it...
