by Gareth » Thu Jul 17, 2008 7:20 pm
Cant get the boss off.
As you will see from this pic there's hex screws that are holding it on. Tried a number of different socket sets/ WD40 but the buggers wont turn.
Any advice. This is of course if that's how you get the hub adaptor/boss thing off. Removed the red cap which reveals a nut which I know will need removed too. If I'm not to remove the hex screws I won't be taking the slagging on my own...there are others involved who will be named and shamed
Gareth on Fri Jul 18, 2008 7:27 am, edited 1 time in total.
by BiggestNizzy » Thu Jul 17, 2008 7:43 pm
temove the nut under the red cap and use a puller to remove ?
by Shug » Fri Jul 18, 2008 8:49 am
Yeah, if you can get at that nut without removing the top plate on the boss, it's the only one that'll need to come off.
H8OAG
by H8OAG » Fri Jul 18, 2008 9:12 am
BMW Z4M40i
Range Rover Velar
2022 Spec Mini JCW
BMW R9T Scrambler Sport
Honda 250 Race Quad
Womaniser Liberty
by Gareth » Fri Jul 18, 2008 9:49 am
Cool, if that's the case Paul G is going to kick my a55
offshorematt
by offshorematt » Fri Jul 18, 2008 6:40 pm
So will I!
More in embarassment though. Must have removed twenty steering wheels in my life and never once had to undo hex nuts - but when you explained the problem I didn't think past getting the b*ggers lose. Doh.
I'll have to give my Cub Scout 'mechanics' badge back now...
thinfourth
by thinfourth » Fri Jul 18, 2008 8:26 pm
I have a set of pullers should it be a bugger to remove
by Gareth » Fri Jul 18, 2008 9:30 pm
thinfourth wrote:I have a set of pullers should it be a bugger to remove
And it is.
offshorematt
by offshorematt » Sat Jul 19, 2008 11:41 pm
G - you get this sorted or do you still need a hub puller?
