S1 elise 111s induction kit
Was considering getting an induction kit for my elise its a 99 111s, does anyone recommend it, and if so which one is best to go for.
S1 Elise 111S
Not got one myself but the most common one is the Hurricane.
http://www.elise-shop.com/index.php?mai ... ducts_id=5
I got the hurricane, bit tricky to fit without taking off the wheel arch liner, but easy enough. Couldn't tell what it did to the noise as I had previously fitted a Larini Club Sport (Which did fit...)
HTH
HTH
or if you're a mechanical nonce like me, you could always just upgrade your existing filter to an ITG panel filter:-
http://www.hangar111.com/ckshop.php?ite ... egory%3D32
Exactly what I did but only cos my old filter needed changed. It made no difference to noise.GregR wrote:or if you're a mechanical nonce like me, you could always just upgrade your existing filter to an ITG panel filter:-
I doubt you will hear it over the Janspeed (Get a Decat, then find a tunnel....c5tto wrote:does it make the engine sound ok? dont want to fit it and find it sounds cheap like a corsa with a filter. my car already has a janspeed exhaust on
