Rear Toe links
Rear Toe links
Toe links, the ball jonts wate are thay off and do we have parts nombers for them?
Re: Rear Toe links
Dunno if they are shared with anything. Lotus aren't actually too expensive to order just the joints. I think Eliseparts have them now too...
Re: Rear Toe links
MMC are about £100 for the 4, latest S2 Service Bulletin standard 10.9 grade steel with K lock nuts (make sure and ask for the nuts and your SE discount!). They'll be able to send them through to MMC Scotland street glasgow for you to collect Hambo.
P.S. Check your rear hbs of course; the alloy ones are a different P/N and are quite a bit more expensive (had one supplied by mistake once). I can get you the P/N's listed in the SB if you require, had the paperwork out last night.
