Help (again)
pete
Vexatious Litigant
Help (again)
Post by pete » Sat Oct 04, 2008 9:06 pm
Does anyone have any idea where I might get the bolt that holds on the hub to the hub carrier. M12 with a slim thread?
Errm the last one was killed in a horrible accident involving Nizzy, me, and angle grinder, a dremmel and a couple of drills.
To be fair it was the grinder which did most of the damage.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Re: Help (again)
Post by robin » Sun Oct 05, 2008 11:45 am
See posting in other thread.
If you can only find a standard mild steel type of bolt I would suggest tightening only to 60Nm or so rather than the 90Nm for the proper bolt - obviously you must only drive the car at low speeds until the correct bolt is fitted.
Re: Help (again)
Post by r055 » Sun Oct 05, 2008 11:50 am
dont know whats in the other thread, but try these guys...
http://www.sjsportscars.co.uk/partsanda ... mit=search
