Battery for 111R
Norway
Battery for 111R
Post by Norway » Thu Oct 16, 2008 9:35 am
Hi
I am looking for some advice. I need to replace the battery and am just wandering exctly what spec I should be getting to replace it, any recommended makes and also any major do's and dont's?
Any advice would be great.
Thanks
Re: Battery for 111R
Post by robin » Thu Oct 16, 2008 1:42 pm
Not sure on 111R battery size.
Check the existing battery - it should have a size code on it - S1s were an 063 code - never changed a battery on an S2, let alone 111R :-)
First rule of working on batteries - disconnect negative terminal first, reconnect negative terminal last.
On the elise, just before you disconnect the battery you need to disarm the alarm/immobiliser, then remove the battery terminal in less than 60s, but certainly before the alarm/immobiliser rearm automatically. If you don't do this, it will go ape ...
