As some of you will know my Head gasget went on FF7 so I decided to upgrade while I was at it. Decided against a pure rod swap since my pistons may have been weakened when the head gasket was gone and I continued to use the car, hard at the Nurburgring. Thought it was safer, (if slightly more work) to replace the rods and pistons for foged items. Also I had ran out of time to sent the rods/pistons away to be machined. Decided on Manley rods and Wiseco pistons, stock size.
You will see from the pic below my bores were still in pretty good shape. You can still see the original cross hatching. There was slightly more wear where the piston skirts touch the cylinder wall. But again you could still see the cross hatching. The bores were very glazed though.
Pic 1
Pic 2
Pic 3
Pic 4
Got the head skimmed as below.
Pic 5
Fitted the new cams. GSC S2's.
Pic 6
Once I got the old rods and pistons out I plastiguaged the crank with the new rods and bearings to check for clearance. These should be 2 thou and seemed spot on. The old bearings showed no sign of wear or overheating so the crank should have been OK. Worth checking though if only not to end up like the Spannish Tuner thread.
Crank
Crank
Crank
New Rod and Piston unassembled.
Rod & Piston
Assembled and fitted the new Rods/Pistons after giving the bores a light hone.
Assembled
Assembled
Assembled
Fitted the ARP head bolts and new head gasket. Stock size at 1mm.
Bolts and Gasket
Bolts and Gasket
Almost together with the new timing belt etc.
And Finally all back together and ready to start.
Luckily I hadn't missed any plugs an it fired up first time after I had turned it over for a bit without the plugs in to let the oil get round the engine.
So all that was finished at 4am in the Friday night Saturday morning before Time Attack Snetterton. Went to bed for a few hours and headed down the A68 to break in the engine the hard way.
Went very well at Time Attack feeling very strong and slightly more pace about it once I upped the boost slightly.
