Sheared bolt
Edin430
Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 12:52 pm
Trying to remove the petrol cap surround and one of the bolts is sheared therefore the allen key won't grip...
Any ideas how I can get it out??
Re: Sheared bolt
Post by BiggestNizzy » Sun Dec 14, 2008 1:03 pm
Drill it out - carefully
Edin430
Re: Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 1:14 pm
I was hoping someone wouldn't say that..... :lol:
Re: Sheared bolt
Post by BiggestNizzy » Sun Dec 14, 2008 1:51 pm
Is the head off the bolt ? or has the hex just been rounded off ?
If you still have the head of the screw you could either ram a torx bit in it or use a small Spiral point tap and a hammer to remove it. this is more risky as a slip could end up being expensive.
To do it you hammer the spiral point tap into the screw so you have esentially a center dab near the outside edge to give you some purchase. then you use this to hammer the screw round.
If the head is off and it's stuck fast drilling is your only option.
Edin430
Re: Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 1:53 pm
Just the hex has rounded off.... Everything else is still there. Allen key just spins round without catching it now! :(
philthy
Re: Sheared bolt
Post by philthy » Sun Dec 14, 2008 1:58 pm
Id go with a sligtly larger torx bit hammer into it, if not then use a drill.
I have some easy outs but they are almost always useless.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
espritstu
Re: Sheared bolt
Post by espritstu » Sun Dec 14, 2008 4:32 pm
hi use a good pair of vice/mole grips,adjust the tension and grip it tight as flat as possible so it marks the caphead then lever the grips Anti-clockwise too loosen,should loosen no problem.
Edin430
Re: Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 4:36 pm
The problem I have is that its embedded down a bit into the filler ring, if that makes sense? So impossible to get anything round it.
Just had someone look at it and he thinks it's going to need drilled for sure which I'm not confident enough to do with it being so close to the clam :oops:
Going up to see Ali mid-week for quite a lot of mods so will just add it to his list of things to do :lol:
Re: Sheared bolt
Post by BiggestNizzy » Sun Dec 14, 2008 5:48 pm
is it a countersink ? and are you fitting a carbon fibre filler ring ?
I am a S1 owner and know very little about S2's
can you snap off the existing ring to releive pressure on the screw allowing it to come out easy ?
Re: Sheared bolt
Post by robin » Sun Dec 14, 2008 7:26 pm
Left handed drill bit in a reversible drill will also work. The hex hole that the allen key should go in will keep the bit from jumping out, but if you're in any doubt about your abilities to hold the drill in place, mask off the surrounding area with a something like an old tarpaulin with a suitable hole cut out of it ... use slow speed and lots of pressure. The screw will come out ... you could also tack weld some welding rod into the head (using an arc welder badly will have just this effect), assuming the screw is earthed.
If you prefer you can also use a normal drill sized to the diameter of the screw to simply remove the head. Once the rest is off, you can then clamp the screw shank with mole grips and it will come out.
Re: Sheared bolt
Post by Rich H » Sun Dec 14, 2008 9:40 pm
Please don't weld it. Normally yes, but given that its on the filler cap.... :thumbsup
Edin430
Re: Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 9:48 pm
Yes that it is being replaced along with many other things.. Thought I could handle this one on my own but clearly not :oops:
Too late to have a go now but will get pics up when I get time during the week and show you what I mean.
Thanks for the instructions Robin :thumbsup I'll definitely be masking it all off and covering with lots of towels just in case..!
pete
Vexatious Litigant
Re: Sheared bolt
Post by pete » Sun Dec 14, 2008 10:23 pm
X7LDA wrote:Yes that it is being replaced along with many other things.. Thought I could handle this one on my own but clearly not :oops:
Dremmel a slot in to the bolt head if you can then use a screwdriver in it?
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Edin430
Re: Sheared bolt
Post by Edin430 » Sun Dec 14, 2008 11:53 pm
Tried that already... Just kept making it worse!
Going to have a go at drilling the top of it, very very carefully.
First time I've actually done this so will see how it goes. :!:
Re: Sheared bolt
Post by robin » Mon Dec 15, 2008 8:22 am
Rich H wrote:Please don't weld it. Normally yes, but given that its on the filler cap.... :thumbsup
It's fine if the fuel cap is in. In any case, unless your tank is almost exactly empty you won't have an explosive mixture in it.
