Bad Roads - Fecked Wheel - Help!
- BiggestNizzy
This morning when Driving to work I went down an almighty pothole/drain or something (big enough to switch the radio off) and now I am left with a squeek when I turn right. The steering is straight and a minor inspection shows nothing has dropped off (it is hard to see anything without popping the wheel off)
Any Idea's what could be making the noise ?
I think I have a puncture too:(
Re: Bad Roads
Rotational squeak with lock on? Maybe shagged the bearing and there is play.
Squeak following road indentations, may be ARB bush buggered and the bar rubbing on something. Or wishbone bush(es)
- BiggestNizzy
Re: Bad Roads
Rotational* sqweek when turning any amount right only, turning left stops it (planning left turn only route home
*although I am not 100% on this as It seemed kinda slow
Re: Bad Roads
Guess it's a case of jacking up and spinning the wheels to see if you can replicate it/check for play. Takes a wishbone-bending hit to damage a chassis pickup and your steering would be wonky. Will be something cheaply replaceable.
- mwmackenzie
Re: Bad Roads
I did the same thing out your way.. well on the muirkirk road 2 weeks ago.... split my wheel new bearing and hub for my borat
over £500 as the whell that were on it are no longer available I had to get a new set... Gutted
It was dark and drizzly so I didn't see the pot hole in question and the only time I go over that way it's dark so I need to find it and get a picture to show the council the state of the roads we're paying for and send them the reciepts for the damage while I'm at it...
Mark
Mark
Re: Bad Roads
Could be something as simple as the little splashguard has been bent slightly so it fouls the disc. Jack it up, spin wheel, see what happens.
Re: Bad Roads
Make sure you contact the relevant council and ask for a claim form for damage to your vehicle. I was actually paid by them at one point for damage to a previous car I had. If the hole has been around for a while you might have a chance.
Re: Bad Roads
Councils aren't great at paying out for this stuff!
Re: Bad Roads
true, IIRC it has to be reported and they have 24hrs to rectify the problem. If you hit it outwith the time given to repair then you can claim for your repairsmeatball wrote:Councils aren't great at paying out for this stuff!
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
Re: Bad Roads
I'm off most of next week if you want to bring it round one day when it's light.
Re: Bad Roads
Yip.....I found that out to my cost in 2006!philthy wrote:true, IIRC it has to be reported and they have 24hrs to rectify the problem. If you hit it outwith the time given to repair then you can claim for your repairsmeatball wrote:Councils aren't great at paying out for this stuff!
- BiggestNizzy
Re: Bad Roads
The car is stuck at my parents, I have lost the locking wheelnut so tommorows job is get the wheels off. (do metro wheel bolts fit ? ) I will do the clio at the same time.
the noise is not rotational it sounds a bit like air leaking out !
I had a look on the way home and couldn't see any pothole !
- mwmackenzie
Re: Bad Roads
How can you report there is a pot hole if you didn't see it until after you drove through it? I only travel the road once a week, hope i'm not stuffed on thisphilthy wrote:true, IIRC it has to be reported and they have 24hrs to rectify the problem. If you hit it outwith the time given to repair then you can claim for your repairsmeatball wrote:Councils aren't great at paying out for this stuff!
Re: Bad Roads
true, they have may well have as little a clue as you do to the pot hole being there so they have to have a reasonable amount of time to fix the fault before it causes problem, annoying I know, Ive had a few cars get egg shaped wheels.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
- BiggestNizzy
Re: Bad Roads
I hate laptops ! this is my second time at typing this in.
Anyway popped the wheels off and found that it is a lovely "D" shape
Does anyone know where I can get a hold of a S1 wheel quick and cheap? The elise is currenly my only car (clio should be on the road by next week) but I need it for my work.
