Any experienece with fitting HID kits?
jamie
Post by jamie » Fri Jan 30, 2009 8:24 am
I got so fed up of the crappy lights last weekend that I have purchased a set of HID lights for the dipped beam.
I am going to attempt to fit them this weekend, any peeps got any recommendations on making the job easier - eg like where to secure the ballasts?
Had a read through the instructions and had a look on the online guides all seems relatively straight forward. Hope I don't live to regret saying that... :roll:
Alex 111s
Re: Any experienece with fitting HID kits?
Post by Alex 111s » Fri Jan 30, 2009 9:08 am
jamie wrote:I got so fed up of the crappy lights last weekend that I have purchased a set of HID lights for the dipped beam.
Jamie,
You'll appreciate the difference.
the job is pretty straightforward.
Wheel off
wheelarch liner out of the way
Headlight lense cover off
dipped beam assey. out
change bulb
open up the gromet a bit & feed HID wires through & connect up.
put back dipped beam assey. in place.
mount balast on the side of the crash structure.
put everything back together.
Check fuse is correct rating & change if necessary. (15amp required for YvoTuk's kits & 10amp installed as std.)
& then off to your nearest MOT test station to get your headlight alignment set.
Alex
Gone :-(111s In Magnetic Blue - Hofmann's Nitrons, Larini C.Sport, Huricane Induction, EBC Ultimax/Yellow Stuff, TD Pro-Race Wheels.
Post by jj » Fri Jan 30, 2009 9:14 am
I never bothered with the MOT re-align - used the garage wall.
Have a look here for photos before and afters - http://www.scottishelises.com/phpbb/vie ... hilit=hids
Alex 111s
Post by Alex 111s » Fri Jan 30, 2009 9:18 am
jj wrote:I never bothered with the MOT re-align - used the garage wall.
So did I.
Alex
jamie
Post by jamie » Fri Jan 30, 2009 9:21 am
Cheers guys :thumbsup
AJT
Post by AJT » Fri Jan 30, 2009 9:44 am
Good fitting guide in the SELOC techwiki
http://wiki.seloc.org/a/Fit_a_HID_kit
Alan
S2 111S
s29ttc
Post by s29ttc » Fri Jan 30, 2009 12:23 pm
Piece of piss don't worry about it. Ive done about 4 or 5 different cars and none have posed as a problem. Just need to get access to the lights and find a suitable place to secure the balast pack! Rest is easy! :thumbsup
1999 S1 Elise 111S - Fun Spec
Post by Mr Momo » Fri Jan 30, 2009 8:33 pm
Jamie,
If you're struggling, Ali @ SLS did mine a couple of years ago - nice neat job. Lights also aligned against garage wall !
Soooo much better :thumbsup
Emira - Volvo spec
knightofni
Post by knightofni » Wed Feb 04, 2009 5:42 pm
Cheap kit off ebay, a dodgy screw meant it took a while, but other than that, not too bad and vast improvement!
Elise 111R - Respect Spec.
Golf GTi - Options, tick, tick, tick, now broke spec.
jamie
Post by jamie » Mon Feb 09, 2009 10:12 pm
I keep putting it off due to pish weather :roll:
I am going to get it done this weekend
jamie
Post by jamie » Sun Feb 15, 2009 6:56 pm
Got around to fitting them today took about 3.5 hrs took a while to get the first one in and ballast secured but the second was mush quicker :thumbsup Big improvement with a nice white 8)
craigs135s
Post by craigs135s » Sun Feb 15, 2009 8:21 pm
Did you take any before and after pics Jamie?
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
jamie
Post by jamie » Sun Feb 15, 2009 8:28 pm
craigs135s wrote:Did you take any before and after pics Jamie?
No I did not - too busy swearing :D
Will take a few now
craigs135s
Post by craigs135s » Sun Feb 15, 2009 8:41 pm
Will take a few now
C :thumbsup
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
jamie
Post by jamie » Sun Feb 15, 2009 8:56 pm
Right, first pic you can see the light reaches way further down the road
From the front
And comparing light temps
