coolant level
vxc
coolant level
Post by vxc » Mon Feb 16, 2009 7:57 pm
where is the fill line, says in the manaul fill between these lines whcih i dont see.
where about should the coolant be up to in comparison to the break line
exige s2
cheers
Re: coolant level
Post by Rich H » Mon Feb 16, 2009 8:45 pm
On most it's normally half way up the tank, but some is good, none is bad. They all sit differently.
Re: coolant level
Post by Dominic » Mon Feb 16, 2009 11:06 pm
The level will also vary subject to how warm the engine is.
Re: coolant level
Post by meatball » Mon Feb 16, 2009 11:37 pm
Aha!
You can see this best from the drivers seat.
When cold it should sit on min (I believe).....best checked when cold?
