How much to replace a wheel bearing?
- skellyjohn
I've just forked out £148 to replace the front nearside bearing. I can't remember it being so expensive in the past and it was just my local garage that done the job. Thoughts?
s1 111s (kind of)
Re: How much to replace a wheel bearing?
Free ball-gag?
Have to think that's a bit of an ouch.. Parts cost is about £20. That means £128 in labour (and VAT, of course) to take off a wheel undo 4 (from memory) bolts - another 2 for the brake caliper, take off a circlip, press out one bearing and press the other one in. Then reassemble. Absolute worst case scenario, with garage tools, it's 2 hours. So £64 an hour labour?
Plus two hours for every single bolt being seized if it's a sheddy old S1
IIRC I paid £60 for each side last time.
"Garage tools" - never seen a spanner monkey waste more than 2 minutes on a seized bolt before the drill comes outrobin wrote:Plus two hours for every single bolt being seized if it's a sheddy old S1
done in the urkin - but its not that easy a job for the DIYer
I think the last wheel bearing I bought nearly two years ago was £43. Also the job can be a PITA so £148 whilst not cheap could well be the true cost to the garage.
Stewart
Was it Gold plated? Seriously though, anywhere with a trade account can get them for £20 - it's a standard Timken part number.Stewart wrote:I think the last wheel bearing I bought nearly two years ago was £43.
- Matelotman
I bought a bearing for about £20, stripped the hub off myself and my local garage pressed it for £10
Thats not all that bad to be honest, I paid 25 for the bearing than took the hub to a garage to be be pressed in for 20.
S1 Elige Audi 1.8T
S1 Elise Honda K20
VW T6.1 family bus
S1 Elise Honda K20
VW T6.1 family bus
No prob with my two sheddies.
Lost count of the number of times that Robin has replaced my wheel bearings at the side of the road/Hotel car parks, in Spain/France/Switzerland/Austria/Italy etc, either pressed them out and in with his thumbs, or called a local yokel who turned up in his 2CV van, took the hub away, then returned before we had sunk a couple of beers and charged a few shekels.
Ball joints and suspension mounts even easier.
Do you know the part number (Timken) as I need two bearing and I can get them from ABC or Scotts bearingsShug wrote:Was it Gold plated? Seriously though, anywhere with a trade account can get them for £20 - it's a standard Timken part number.Stewart wrote:I think the last wheel bearing I bought nearly two years ago was £43.
Kinnon
- Matelotman
I got mine from this boy - quick delivery, no probs and part is a Timken part
http://cgi.ebay.co.uk/LOTUS-ELISE-FRONT ... 240%3A1318
Timkin JRM3938Akpb wrote:Do you know the part number (Timken) as I need two bearing and I can get them from ABC or Scotts bearingsShug wrote:Was it Gold plated? Seriously though, anywhere with a trade account can get them for £20 - it's a standard Timken part number.Stewart wrote:I think the last wheel bearing I bought nearly two years ago was £43.
Kinnon
Taken from the sticky post at the top of this forum entitled "Part Numbers"
Thanks for that Shug, note to self learn to use the forum correctly
I have ordered two from ebay £19.99 each +£6.90 post as Matelotman advised.
Thanks to all
Kinnon
Thanks to all
Kinnon
