toyo t1r front / a048 back
is this a bad idea?
they found a nail in one of my front tyres and i just dont have the funds just now to get a048's or r888
They are due replacement so i might as well get 2 done at same time..
Is this wise>?
Is this wise>?
Re: toyo t1r front / a048 back
I guess it all depends on how much you like hedgesvxc wrote:is this a bad idea?
Is this wise>?
Exige V6
really?neil wrote:I guess it all depends on how much you like hedgesvxc wrote:is this a bad idea?
Is this wise>?
zero grip at all?
the fastest i would normally go would just as fast you would drive say a fast hatch back. not a big speedster myself !
but if its a no go then i think i will r888 them>!
I've not done it myself, but from what I've heard mixing A048's or R888's with anything else can make the handling "interesting"
See http://www.scottishelises.com/phpbb/vie ... hp?t=16777 for one example
Exige V6
I would go for the R888's.
I wouldn't mix the t1r's.
my 2p
my 2p
yeah thanks. think i will be wise and get r888's
I found them for £104 inc vat
good price?
good price?
cack just realised all the placed i found seem to be out of stock! buggor!
Well, I looked around and found some good prices then it was pointed out to me, correctly, that Ronnie at Wheelsaround looks after us at Knockhill (which makes life easier for a lot of SE'rs) and that we should try to support him where possible......as such I went to wheelsaround.
http://www.wheelsaround.com/
The choice is yours!
Not zero grip but a huge imbalance between front and rear. Bad idea.vxc wrote:zero grip at all
I`m pretty sure we have a pair of part-worn fronts, I have asked the motorsport facility manager (philthy) to have a look tonight when he gets home. I`ll let you know.
jj wrote:I`m pretty sure we have a pair of part-worn fronts, I have asked the motorsport facility manager (philthy) to have a look tonight when he gets home. I`ll let you know.
the t1rs will have f*** all grip, the 48s when warm will have loads.
You will have the worst handling, understeery car ever, until the snow comes, at which point things may change somewhat
I used to run slicks on the front of my 306 Rallye and 888's on the back for track days
(that's why I think Mike will do fine, that and his lack of imagination).![]()
NOOPS 160 wrote:I found a screw in my front R888's a fortnight after I bolted them on brand new... 5K on and two track-days later its still there....vxc wrote:is this a bad idea?
Is this wise>?![]()
. I screw the bloody thing in further every now
, and then and keep a tight check on psi..
you risk blow out surley, !
i couldnt take that risk.....
And to think we trust this man with guns.
