Rear clam removal
offshorematt
Rear clam removal
Post by offshorematt » Mon May 01, 2006 8:06 pm
How hard a job is this then? The hinge pin on my engine cover has sheared and I believe that access is through rear clam removal :cry:
Post by Gareth » Mon May 01, 2006 8:54 pm
Helped Uldis remove his.
Two man job.
It's an easy job ...
Post by robin » Mon May 01, 2006 9:44 pm
Except that it will be really hard because every fastener will probably be seized.
You will need two people.
My pin is also broken - I have simply ignored it :-)
Good luck!
Re: It's an easy job ...
Post by Gareth » Tue May 02, 2006 7:48 am
robin wrote:Except that it will be really hard because every fastener will probably be seized.
Yup, you can guarantee that!
Post by Shug » Tue May 02, 2006 9:23 am
Mine wasn't <smug>
8)
offshorematt
Post by offshorematt » Tue May 02, 2006 11:23 am
I like the leaving it option. When the second pin snaps which it invariably will, I'll consider looking at it. If it ain't completely broke...don't fix it. :lol:
blackbird
Post by blackbird » Sun May 07, 2006 12:17 am
you dont need to take the clam off to fix the pin check and see if the pin which is a bolt ,there are 2 of them has not just come undone .to check undo the bolts the fix the rear of the clam this lets you lift it up and fit a new bolt hope this helps you :wink:
offshorematt
Post by offshorematt » Mon May 08, 2006 12:37 pm
I took the back window out at the weekend and looked down the crack - the bolt looks like its backed out of the hinge. I reckon if I unbolt the clam along that edge I can probably pull it up far enough to get onto the bolt. Does it just screw into a captive nut?
blackbird
Post by blackbird » Wed May 10, 2006 10:17 pm
yes fit it with some thread lock
