Road spring compressors on Elise
Tim S
Post by Tim S » Sun Feb 22, 2009 8:40 pm
Before I bother buying a set, can anyone advise whether normal types of road spring compressors can be used on the Elise with the spring/damper in place - or do the wishbones get in the way??
(In case anyone's wondering, wanting to do this to shorten the springs and hence make it easier to adjust the ride height).
Thanks
Tim
Re: Road spring compressors on Elise
Post by Rich H » Sun Feb 22, 2009 9:23 pm
I think that you need some very thin ones as there isn;t a fat lot of room between the coils
Post by robin » Mon Feb 23, 2009 7:35 am
I don't think you need them for nitrons ... use a punch or a long hex key of the appropriate diameter and insert into the hole on the collar and turn; for any reasonable ride height, the preload is so small that this should not be a problem.
