ECU reflash
Andy A
ECU reflash
Post by Andy A » Thu Mar 05, 2009 8:47 pm
I have been thinking about getting the ecu reflash done on my exige na
is it just a case of unbolting and unplugging or does the battery need disconnecting? will
it feck up the alarm and so on.
Thanks for your help
Andy
ryallm
Re: ECU reflash
Post by ryallm » Thu Mar 05, 2009 9:11 pm
Just unplug the ECU and send it off. No probs with the alarm. It is a great upgrade and really well worth doing :thumbsup
Mark
Re: ECU reflash
Post by robin » Fri Mar 06, 2009 8:14 am
Whilst you can just disconnect the ECU without disconnecting the battery, it's so easy to disconnect the battery on the S2 that if it were me, I would disconnect the battery first (and remember to disarm the alarm/immobiliser immediately before disconnecting the -ve terminal).
