Fan Heater...
Fan Heater...
My fan seams to only be blowing hot air, no matter where I turn the knob
Has anyone had the same problem?
Re: Fan Heater...
Similar - mine blows only cool air.
There's a cable or lever under one of the front access panels, which controls whatever flaps exist to move the air about - this may have become loose or jammed (try a search for more details, I'm sure it's been posted before.)
A solenoid valve/actuator might be involved in making the neccessary movements, so it may be the case that this needs replaced.
Re: Fan Heater...
Same happened on mine recently - well, stuck hot. Turned out to be electical connector accessed from the offside front access panel - nothing mechanical. You can check if it's this with a multimeter, cos the voltage in the connector changes when you change the heater dial. Pulled the connector apart, sprayed with WD40 and put back togther and works again...for now at least.
Tim
Tim
Re: Fan Heater...
Sorry for the late reply , thanks for the advice iv had a poke around but i think i need to take the clamshell off which im not brave enough to take off myself . How is your heater now ?Scott M wrote:Similar - mine blows only cool air.
Re: Fan Heater...
Sorry for getting back so late, iv had the pannels off and a poke around but didnt get very far . Im going to have another go at it this weekend .Tim S wrote:Same happened on mine recently - well, stuck hot. Turned out to be electical connector accessed from the offside front access panel - nothing mechanical. You can check if it's this with a multimeter, cos the voltage in the connector changes when you change the heater dial. Pulled the connector apart, sprayed with WD40 and put back togther and works again...for now at least.
Tim
Re: Fan Heater...
I've got the opposite problem, only blowing cold air (which shouldn't be a problem in the summer time, eh?
Had the service panels off at lunch time, got the ducting out, and right enough the wee flap didn't move when I turned the switch. Checked all the electrical connectors were connected but I didn't have my multimeter so couldn't check what was wrong.
Put it all back together again having achieved nothing, magic!
S2 111S blue with silver stripes - The Good
56 Astra in black - The Bad
Rover 45 in maroon - The Ugly
Re: Fan Heater...
.... and mine doesn't blow hot or cold
- point n squirt
Re: Fan Heater...
Mine used to blow hot then all winter cold now its somwhere in the middle,that will do.
Re: Fan Heater...
I am starting to think I could live with hotrenmure wrote:.... and mine doesn't blow hot or cold
