craigs135s
by craigs135s » Sat May 13, 2006 5:19 pm
Just fitted some new green stuff all round. Only problem is they are squeking like fook. what have i forgot to do????
Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
- Site Admin
by simon » Sat May 13, 2006 5:53 pm
Put copper grease on the backs of the pads or fit anti squeal buffers on the backs. Saying that, when I had greens on mine I did neither and they never squealed.
craigs135s
by craigs135s » Sat May 13, 2006 6:02 pm
Got the buffer pads do they go on front and back?
Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
- Site Admin
by simon » Sat May 13, 2006 6:09 pm
Depends what you mean by buffer pads.
There are small pads that go directly on to the caliper to stop the front pads rattling about. AFAIK, they're not the same as the anti-squeal pads that go on the pad backing.
- Site Admin
by simon » Sat May 13, 2006 6:11 pm
craigs135s
by craigs135s » Sat May 13, 2006 6:28 pm
Its the squeal ones i have mate. Should i fit these to front and back pads??
Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
by Shug » Mon May 15, 2006 9:46 am
Other thing to do is to bed them in properly. You need to give them a proper hammering, then cool them to heat cycle them a couple of times.
I find at least 5 (to the point of lockup) hard stops from ~100tuts, without actually letting the car stop. I've got a section of (closed private, obviously) road with a roundabout at each end, that I can blast to the ton between and circualate the roundabouts to cool before going for another run. Makes em last longer and I don't get squeal - that's without using any squshy anti-squeal pads, just a coating of copaslip to the back of the pad.
