high pitch whine
ticktickboom
high pitch whine
Post by ticktickboom » Tue May 26, 2009 11:11 pm
there is a whine that raises in pitch from behind my seat when i apply revs, extremely annoying.
any ideas?
vxc
Re: high pitch whine
Post by vxc » Tue May 26, 2009 11:35 pm
s charger ? :P
tenkfeet
Post by tenkfeet » Tue May 26, 2009 11:40 pm
Alternator belt if a K .
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Post by r055 » Tue May 26, 2009 11:47 pm
its usually the wife...
neil
Post by neil » Wed May 27, 2009 12:24 am
r055 wrote:its usually the wife...
Behind the seat?? :shock:
Exige V6
Post by tut » Wed May 27, 2009 7:56 am
Which model?
whaleys
Post by whaleys » Wed May 27, 2009 9:48 am
Second the alternator belt if a K statement. Mine does it too. Although it shouldnt be too loud mind you :shock:
paulW
Post by paulW » Wed May 27, 2009 9:58 am
had the bearing in the alternator go, with similar symptoms. There's a place in Bellshill that does a refurb for £90 if it is the alternator.
ticktickboom
Post by ticktickboom » Wed May 27, 2009 12:49 pm
S2 111s k-series. Thought that may be it, had problems with it squeeling not long ago.
roadboy
Post by roadboy » Wed May 27, 2009 1:06 pm
Most likely the rear bearing in the alternator. They are a common fault on the Bosch alternators fitted to S2s.
Dan
SPS Automotive
Independent Lotus Specialists
Post by robin » Wed May 27, 2009 10:21 pm
I have an S2 spare alternator if you want to fit it to see if the noise goes away ...
EDIT: Of course you could just take the belt off for a while and see if the noise goes away - that would be easier actually - as you were ..
bertieduff
Post by bertieduff » Wed May 27, 2009 10:59 pm
paulW wrote: There's a place in Bellshill that does a refurb for £90 if it is the alternator.
Paul, mine is gubbed too- any more info on the place you mention?
paulW
Post by paulW » Wed May 27, 2009 11:29 pm
Not sure, might be this place.
Shandon Electrical. Belgrave St, Bellshill Industrial Estate, Bellshill, ML4 3JA Tel:01698 843602
Was certainly on Belgrave Street, as I worked just on the other side of the carriageway. I can try to find out.
whaleys
Post by whaleys » Thu May 28, 2009 11:16 am
I got a new alternator from here...
http://www.woodauto.com/Component.aspx?Ref=ALT10027
When I bought it, it was £95 but its gone up to £136. They are brand new and dont require your old one in exchange.
Thats for the S2 k-series though.
Graeme
ticktickboom
Post by ticktickboom » Thu May 28, 2009 12:25 pm
robin wrote:I have an S2 spare alternator if you want to fit it to see if the noise goes away ...
i wouldnt have the foggies notion of how to do either. cheers for the offer though :D :thumbsup
think ill just do the usual and book into murray's.
