Anyone fancy looking at a 111r throttle body in the morning!
Post by Andy G » Fri May 19, 2006 4:16 pm
Doesn't look like MMC are coming back to me on this one today!
If anyone is handy enough to embrace a 111R throttle body let me know as tomorrow morning I'd love to have a look at it :D
Sounds like it is sticking, and someone down south has the same issue....he's now on his 2nd throttle body :( :(
Post by Shug » Fri May 19, 2006 4:37 pm
Would love to, but I'm occupied all bloody day (and night, for that matter ;) )
Post by ed » Fri May 19, 2006 4:46 pm
:puke <BG>
Post by Shug » Fri May 19, 2006 4:48 pm
Tch, I'll be sure and tell Elaine that's what you think of her..... :roll:
Post by ed » Fri May 19, 2006 4:51 pm
Believe me i wasnt talking about elaine! :wink:
Post by Rich H » Fri May 19, 2006 5:40 pm
Knowing next to nought about the 'yota, can you get to it easily? If so a good old clean out with some spray switch cleaner (Isopropyl Alcohol or similar) probably wouldn't go a miss. Then a dose of white lithium grease to stop it happening again.
I use this on almost anything electrical and sticky (Make of that what you will :roll: :lol:) and it normally works a treat as long as something isn't broken.
Pics or a snippet from the service manual?
Post by Andy G » Fri May 19, 2006 6:37 pm
cheers Rich.
Can't find the sodding thing in the service manual.
Might have to leave it for mmc and clean out the induction kit tomorrow :D
Lawrence
Post by Lawrence » Fri May 19, 2006 10:15 pm
I should be here in the morning Andy if you want to take it off and clean it
Post by Andy G » Sat May 20, 2006 2:37 am
Lawrence wrote:I should be here in the morning Andy if you want to take it off and clean it
where abouts are you lawrence?
Feel free to PM or call me on 0778 8163201
Lawrence
Post by Lawrence » Sat May 20, 2006 9:39 am
Post by Andy G » Sun May 21, 2006 10:15 pm
thanks so much for yesterday LAwrence!
HOpe KAirns went well today. Didn't make it as i ended up rescuiong a damsel in distress and taking her to glasgow :shock: :D
Post by alicrozier » Sun May 21, 2006 10:49 pm
What was the outcome folks?
Sorry I couldn't help at the time but now back online.
Post by Andy G » Mon May 22, 2006 9:32 am
Took the throttle body off and cleaned it. Couldn't get one of the sensors off though, as it had a 5 start anti-tamper screw holding it on! Now just need to get MMC to reset the MIL light to see if we have solved the problem. There was a lot of crap in there, so hopefully that was causing the high rpm warning.
Definetly worth making a point to everyone that if you have an induction kit fitted be sure you keep it well serviced, as mine was doing SFA in its current state!
PhilA
Post by PhilA » Mon May 22, 2006 9:45 am
Andy G wrote:Couldn't get one of the sensors off though, as it had a 5 start anti-tamper screw holding it on!
aye, that'll be the MAF - they are held on with security torx (spelling) screws.
hope thats it sorted, tho id still be thinking of changing the sensor to be sure things working properly with regards air/fuel mixture.
Phil
Ford Focus Sport
Lawrence
Post by Lawrence » Mon May 22, 2006 9:48 am
No not the MAF
Held on with a 5 point version of a normal 6 point torx
