Noise Level 100db
COKO
Noise Level 100db
Post by COKO » Mon Jul 13, 2009 12:38 pm
Hi,
We have organissed our anual trip away this year to Castle Combe on the 7th Aug. the noise level is < 100db. The 7x S1s are all the same with CAT removed and sports box. Is there anyone going to Knockhill tonight that could bring a db meter.
Also: If we had a failure is there anything we could fix on or some way we could reduce noise by inserting some made up baffle ?
Regards
Coko
Re: Noise Level 100db
Post by robin » Mon Jul 13, 2009 2:26 pm
100db is quite loud, but if your back boxes don't have any baffles or packing in them, then you can easily see 120db.
There aren't any quick fixes to this, other than to refit a more baffled exhaust, or to repack the ones you have if they're repackable.
Bolting a baffle onto the tail pipes is unlikely to work, and the marshalls may not be all that happy with it either, as these pipes often get blown off and become a hazard.
If you're in doubt, book-a-track used to offer to send a noise meter to you by post for a deposit - you could then test your car before you went to the circuit - or you could buy one from, e.g., Maplin:
http://www.maplin.co.uk/Module.aspx?ModuleNo=226470
It's only 20 quid - it'll save you a hell of a lot of trouble later on ...
roadboy
Post by roadboy » Mon Jul 13, 2009 2:27 pm
Is it a static test or drive-by at Coombe?
If its drive-by the static test won't help much.
I will be at Knockhill on Monday and will have my noise meter with me.
Dan
SPS Automotive
Independent Lotus Specialists
Post by tut » Mon Jul 13, 2009 2:30 pm
Are you coming to ours next week Dan?
Post by alicrozier » Mon Jul 13, 2009 2:32 pm
roadboy wrote:Is it a static test or drive-by at Coombe?
Dan
Looks like a static test:
http://www.castlecombecircuit.co.uk/exp ... p?ExpID=13
Peter
Post by Peter » Mon Jul 13, 2009 3:07 pm
You can get a free db meter for the i-phone , claims to be +- 2db. Might put your mind at ease?
roadboy
Post by roadboy » Mon Jul 13, 2009 3:53 pm
tut wrote:Are you coming to ours next week Dan?
Yup.
Dan
SPS Automotive
Cisco
Post by Cisco » Tue Jul 14, 2009 9:58 am
Dan
I've only done one T/D at Castle Coombe, nearly two years ago, at that time it was static noise test same as Oulton.
Take care,
Frank
