A048's / R888
ClarkyBoy
A048's / R888
Post by ClarkyBoy » Thu Jul 16, 2009 5:14 pm
Hi Guys,
Whats best for me?
My S2 only gets used at weekends/nice days and SE runs/trackdays, so im not worried about the tyres being any use in poor weather,
Also anyone know where i would be best to get these for the best price (come one im from aberdeenshire!) :lol:
Help and advice would be much appreciated.
Thanks.
Vanlife Sprinter
E30 318is / axle stand spec
987.2 Cayman S
[#]=///=[#] ‘88 Panda 4x4
BSA B31
MF35
Stiga Tornado
Many Bicycles
Re: A048's / R888
Post by tut » Thu Jul 16, 2009 5:26 pm
Clark
If you want to use an R tyre then Ronnies prices are unbeatable for the 48R's. I have just posted the prices on the Knockhill thread.
Re: A048's / R888
Post by Mikie711 » Fri Jul 17, 2009 7:25 am
tut wrote:Clark
What he said :thumbsup
neil
Re: A048's / R888
Post by neil » Fri Jul 17, 2009 11:02 am
If you're sticking R tyres on it will you not have to do other things too like upgrade your toe links?
Exige V6
Re: A048's / R888
Post by tut » Fri Jul 17, 2009 11:04 am
Yep if he is going to track it, virtually essential.
ClarkyBoy
Re: A048's / R888
Post by ClarkyBoy » Fri Jul 17, 2009 11:42 am
thanks for your help guys, :cheers
So for light road/track use, what all would i need to do prior to me fitting road legal slicks? :?
Vanlife Sprinter
987.2 Cayman S
BSA B31
MF35
Stiga Tornado
Many Bicycles
Re: A048's / R888
Post by tut » Fri Jul 17, 2009 11:50 am
Change your old brake fluid if you have not done so yet, I think 4.1 is the recommended.
Decent brake pads.
Upgraded rear toe links.
I would think that should do.
steve_weegie
Re: A048's / R888
Post by steve_weegie » Fri Jul 17, 2009 11:58 am
Tut, I think that the toe links on the S2 should be OK as standard for the R tyres - but just check that they are in good condition. I've had several sets on my car without issue. Was a concern on the S1 AFAIK??
What wheels do you have? The A048's will go on the standard S2 front J5.5 rim, but its at the limit of what is recommended for the M and MH compounds. If you can invest in a set of J6 or J7 fronts, you'll get more out the tyres. Either way, I'd also be looking for a geo setup too... A bit more -ve camber at the front is what's called for, possibly coupled with a slight increase at the rear too, to balance things up :thumbsup
Re: A048's / R888
Post by alicrozier » Fri Jul 17, 2009 12:04 pm
Ask Mc Ape about the toelinks... :shock:
Best to upgrade them.
What suspension is on the car? If it's standard it will be too soft for R rated tyres.
Better to upgrade the suspension and tweak the geo first...then think about more tyre grip.
steve_weegie
Re: A048's / R888
Post by steve_weegie » Fri Jul 17, 2009 12:15 pm
alicrozier wrote:Ask Mc Ape about the toelinks... :shock:
Even on the S2 Ali?? I thought they were Ok? :scratch
Just found this too :?
SELOC TechWiki wrote: You don’t have to have solid/uniball rear toe links to run cut slicks - Lotus shipped the S2 135R and Exige on A048s with standard toe links, and there are many thousands of track miles done each year on these with an extremely low failure rate (the major problem was the S1 design) ...
Re: A048's / R888
Post by mac » Fri Jul 17, 2009 12:23 pm
That was also the advice I got from Lotus Motorsport - of course it doesn't cover ALL driving styles :D
I'm still on the original set of toe links and have done a fair bit of track mileage on 48's
Re: A048's / R888
Post by alicrozier » Fri Jul 17, 2009 12:30 pm
They are better than the S1 but still break.
My original S2 Exige had upgraded rear toelinks as part of the Performance Pack...
Depends on your driving style I guess. Personally I would upgrade.
Re: A048's / R888
Post by mac » Fri Jul 17, 2009 12:32 pm
I know that exiges could be specced to have a single bar from wheel to wheel - I had discussed taking the elise down to hethel to have the same thing fitted to mine too.
But I gave up trying to turn it into something it's not and bought the 7 instead.
Re: A048's / R888
Post by mckeann » Fri Jul 17, 2009 1:07 pm
Personally, i'd run the eliseparts uniball toe link, and change the bolts every year
ClarkyBoy
Re: A048's / R888
Post by ClarkyBoy » Fri Jul 17, 2009 1:39 pm
Thanks for all of your advice guys,
alicrozier wrote: Depends on your driving style I guess. Personally I would upgrade.
As for driving style tut would probably be the best person to judge, as he has now spent 6-700 miles directly infront/behind me lately, my s2 is on standards racetech suspension(dont know if the racetech has different sus?) but its bilstiens, and tut reckons my car is more stable than his on the road (as he discovered whilst leaving the ground on the 050709 trip :lol: ) and he runs nitron's,
tut wrote:Change your old brake fluid if you have not done so yet, I think 4.1 is the recommended.
Decent brake pads.
i will get my brakes completely worked over - fluid+pads replaced, calipers cleaned up slides copper greased etc. when i get back from london at the end of the month.
Vanlife Sprinter
987.2 Cayman S
BSA B31
MF35
Stiga Tornado
Many Bicycles
