by Gareth » Sun May 28, 2006 9:27 pm
OK, bare with me.
I've been working on the brakes today at my mates.
Changed the fluid there and went home to change the pads.
So, I've just noticed that both front tyres; the rotation arrows are pointing the wrong way. Rotation showing backwards. So, if I put the drivers side wheel on the passenger side that will be fine but even if I put the passenger side on the drivers side it will still be wrong. This tyre must be fitted to the wheel the wrong way round
If this is the case, surely this is something MMC would of noticed or am I missing something?
- Dodgy Dave the Ba***rd
by DDtB » Sun May 28, 2006 9:45 pm
Have you been drinking???
by Gareth » Sun May 28, 2006 9:59 pm
You would think....
Scottd
by Scottd » Sun May 28, 2006 10:07 pm
Could be wrong way round, previous owner might of swapped front wheels around or summin which I think would send the direction the wrong way. A bit odd tho. What tyres is it?
scott
by Gareth » Sun May 28, 2006 10:19 pm
Oh, Yoko 48's....
Isn't the pattern symetrical therefore wont matter??
- Site Admin
by simon » Sun May 28, 2006 10:24 pm
48s are not sided but are obviously directional so if both fronts are the wrong way round, you should be able to swap sides and that'll fix it. Like I said before, how you do that without a set of axle stands or a spare wheel I don't know
Scottd
by Scottd » Mon May 29, 2006 12:43 am
simon wrote:48s are not sided but are obviously directional so if both fronts are the wrong way round, you should be able to swap sides and that'll fix it. Like I said before, how you do that without a set of axle stands or a spare wheel I don't know
Bricks? It's worked for generations of pikey wheel thiefs!
scott
