Source for shock bolts and nuts?
I've had my VX thoroughly serviced and checked out now and my front left damper is leaking. You can feel it under braking - the car skips to the left then right before settling into the braking proper.
I had a feeling the shocks were on the way out so I bought a set of secondhand spring/damper units from a VXR to see me through until I get proper race dampers. I understand that its easy to replace the units (two bolts) but I wondered if there was a good source of the bolts, nylocs and washers as I'd feel better replacing these when I change the shocks over. Where do you guys buy your nuts and bolts?
Kev
Kev
My racing blog: www.racingfive.co.uk
2001 VX220 NA - SOLD
2002 Seat Alhambra - family towcar shed
1996 Volvo 940 Sports Edition - winter shed
1983 Mercedes 280SE - dictator shed
2001 Citroen Saxo VTS - hillclimb shed
Re: Source for shock bolts and nuts?
Bell & Colvill stock the Lotus ones, you could go to your local Vauxhall dealer they would be able to supply the correct ones.
As AboveMikie711 wrote:Bell & Colvill stock the Lotus ones, you could go to your local Vauxhall dealer they would be able to supply the correct ones.
I get all my parts from Bell & Colvill. Good guys to deal with and a quick delivery.
Don't have my parts manual handy but if you want the Part Numbers i can look them up
Alan
After Mikes advice I am getting a complete bolt refresh kit from Yvo which includes the damper bolts, but I also need all the wishbone bolts, so at 26 pieces it is probably over the top for you.
Excuse my ignorance, tut but what is Yvo?tut wrote:After Mikes advice I am getting a complete bolt refresh kit from Yvo which includes the damper bolts, but I also need all the wishbone bolts, so at 26 pieces it is probably over the top for you.
Suspension refresh is one of my potential winter projects but I need to change the dampers to keep me safe until them (I've foolishly entered the VX at Forrestburn at the end of the month).
Kev, assuming the VX is the same as the elise S1 then these are the bolts you need from Bell & Colvill. The two longer ones are for the top front mounts, the ones with the top hats.
They have a good reputation but some of their prices are eye watering.
S1 headlight covers at £160, I paid £35, rear toe link set £650.
I'm pretty sure they'll be be the same - I notice they fit S1, S2 and all Exige models. For £17 there's one way to find out.........Mikie711 wrote:Kev, assuming the VX is the same as the elise S1 then these are the bolts you need from Bell & Colvill. The two longer ones are for the top front mounts, the ones with the top hats.
£17 for 8 nuts and bolts!!!
Why not just go to a local fastener distributor and pick them up for pennies. They're not exactly anything special. Just standard metric nuts and bolts.
Dan
Dan
Quite, cost you a quid from an engineering supplier . . . AA components for example in Stirling I used to use . . . and even they are fleecing you !
Fd
Fd
- BiggestNizzy
bolts cost pence if you buy them in any sort of bulk even a small box of them is relativly cheap. you need to find someone who is willing to split a box and sell individual screws.
Or you could buy boxes of the sizes you need and flog them for 20p each and still make a killing
Quite. But who is that person who will split them and if i have to spend more than 15 minutes finding this person, I'd be better off being fleeced by Bell & Colvill. Time is money.......BiggestNizzy wrote:bolts cost pence if you buy them in any sort of bulk even a small box of them is relativly cheap. you need to find someone who is willing to split a box and sell individual screws.
BTW, Autovaux quoted me £92 !
kevham wrote:Quite. But who is that person who will split them
If anyone is looking for anything (small or large quantities) then just give me a shout. We'll send them in the post as well if you're not local.
Gary - Grampian Fasteners, Dyce, Aberdeen.
Exige GT
Gary, I have decided to go local as Yvo's work out at £40 with postage. If I send you a list would you be able to do them for me?
All M10 HT 8.8 from 55mm to 130mm x 24. Ian or Clare could pick them up.
