Talking to tintops
- thinfourth
Talking to tintops
Yes the one and only modernish car we have has a habit of the dash lighting up like a pinball machine
Now we stuck it into a garage to get it looked at and they charged £50 to say yep there was some faults but we cleared them and it is fine now
2 days later and it does it again
Now how do i talk to the car so i can read fault codes such as ABS faults etc
Re: Talking to tintops
What car, what age, etc . . . if it's ODBII then you can buy a cheapo reader off the bay . . . the older the car the less likely it is to be 'standard' . . .
Fd
Fd
- thinfourth
a 2003 vintage vauxhall disastra
If it's that age it'll be ODBII. I've got a reader if you want a shot
Exige V6
- thinfourth
Sounds like a plan
Then i can see what this white mans magic is all about
You won't be able to get ABS or Airbag codes from a Standard EOBD reader though. It will only give you powertrain related codes.
You need manufacturer specific stuff for the other ECUs.
HTH
Dan
HTH
Dan
- thinfourth
Oh bugger
At least some knows what they are talking about
Any recommendations for a do it all solution as i don't want to end up with another vauxhall
Their pap
Their pap
Have a search on ebay for op com. It's for vauxhalls and can read all ecu's in the car i.e airbag/abs/engine
