Engine won't stop
Engine won't stop
Post by Stephen » Sat Oct 03, 2009 8:49 pm
For some reason my engine is not stopping when I take out the key?
It stops eventually but seems to use up the fuel in the pipes first. Any Ideas?
Thanks & sorry for not bing on for a while.
Re: Engine won't stop
Post by mckeann » Sat Oct 03, 2009 9:01 pm
i have some very vague memory of this being something to do with the power to the cigarette lighter. have you been fiddling with that recently?? IIRC its when you reconnect it with the wires the wrong way round, but this might be total and utter crap
Post by Stephen » Sat Oct 03, 2009 9:04 pm
It's had a new thermostat water pump and HG fitted, but i have not been fiddling lately - been too busy!
craigs135s
Post by craigs135s » Sat Oct 03, 2009 10:02 pm
When i first got my exige when i had my lights on i could take the keys out and it would not stop but when i turned the lights off it would. That turned out to be the wires round the wrong way in the cigarette lighter.
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
thinfourth
Post by thinfourth » Sun Oct 04, 2009 6:44 am
Is the radiator fan running when it does this?
roadboy
Post by roadboy » Sun Oct 04, 2009 7:57 am
Most likely the MFRU.
HTH
Dan
SPS Automotive
Independent Lotus Specialists
Post by robin » Sun Oct 04, 2009 8:31 am
Is the rev counter showing engine speed or zero while it's running on?
If you open the throttle a little bit while it's in this state, what happens - does the engine rev up or stall immediately?
If this all only happens when the lights are on, then it's the cigarette lighter wiring, most probably.
Post by robin » Sun Oct 04, 2009 8:34 am
roadboy wrote:Most likely the MFRU.
HTH
Dan
Hi Dan,
Out of interest, what's the MFRU failure mode that causes this condition? Is it that the main relay doesn't release but the fuel pump relay does? Even so I would expect the ECU to stop spark/fuel once the ignition sense wire goes inactive - perhaps not though - who knows!
roadboy
Post by roadboy » Sun Oct 04, 2009 4:46 pm
Seen it quite a few times Robin.
The Main Relay not releasing will cause the engine to run on until it runs out of fuel in the rail. Usually caused by water/corrosion inside the MFRU.
Dan
SPS Automotive
Post by tut » Sun Oct 04, 2009 5:05 pm
If the cigarette lighter terminals have not been reversed, why would that be a possible cause?
Post by r055 » Sun Oct 04, 2009 5:30 pm
craigs135s wrote:When i first got my exige when i had my lights on i could take the keys out and it would not stop but when i turned the lights off it would. That turned out to be the wires round the wrong way in the cigarette lighter.
C
that will be why you killed my TOMTOM charger on way back up the M6 :lol:
craigs135s
Post by craigs135s » Sun Oct 04, 2009 8:00 pm
C
Your right :mrgreen:
C
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
Post by Stephen » Sat Oct 10, 2009 1:37 pm
It seems to have sorted itself so will look out for the suggested symptoms should it happen again.
S
