I'm looking for some guidance on a problem with my 2000 s1.
There is a noise, a bit like the hum of a spinning top coming from the rear of the car. It becomes audible about 25mph but less noticeable above 50mph, but I think this is because it is masked by the general racket of exhaust and tyre noise.
Initially, I thought it was a rear wheel bearing, but there was no difference in the noise between left or right bends. I jacked up the car the other day and spun the wheels up to speed, first one side and then the other. I think the noise was equally loud and coming from the inboard end of the driveshafts.
There is no clunking sounds and the noise varies with wheel speed, not engine speed. It makes no difference if the clutch is engaged or not.
The car has only done 30k, but I am suspecting a gearbox problem. Has anyone come accross a similar problem?
Thanks, Angus
