OBD II Reader
Andy H
OBD II Reader
Post by Andy H » Mon Dec 28, 2009 7:01 pm
Anyone got one ?
What make, any good ?
Going to have a look at costs etc.
Thanks
Andy
Andy H
Re: OBD II Reader / Just Ordered
Post by Andy H » Tue Dec 29, 2009 6:56 pm
http://www.talktomycar.co.uk/products/c ... /mj007.htm
X-Mass presie to self Autel MaxiScan MS509 for £85 because of £20 off.
Daughter has a Focus as do I.
MMC siad I should be able to get the fault codes as the 160 Sport has a EFi not the GEMS.
Ill let you know how I get on.
Andy
Gourlay83
Re: OBD II Reader
Post by Gourlay83 » Wed Dec 30, 2009 9:41 am
Hi Andy,
I have been through quite a few of the cheaper ones. Work a couple of times then pack in (at the worst times). It took me a few attempts to find a reliable one so your probably done the right thing by spending a bit more money on a good one.
You should be fine with that one, i have loads of software for them if you dont like what comes with it.
Alan
Re: OBD II Reader
Post by mwmackenzie » Wed Dec 30, 2009 3:07 pm
Does an S1 have an OBD2 port? :?:
Gourlay83
Re: OBD II Reader
Post by Gourlay83 » Wed Dec 30, 2009 3:20 pm
Yes, Its inside the boot close to the Left Hand Rear longeron although mine is an alloy boot. Believe the fibre glass ones are in a different place.
I use them on other cars as well.
Alan
Re: OBD II Reader
Post by mwmackenzie » Wed Dec 30, 2009 6:45 pm
I thought that was an OBD1 on the S1? Not sure though hence the question...... :?
Gourlay83
Re: OBD II Reader
Post by Gourlay83 » Wed Dec 30, 2009 8:20 pm
Your right in a way,
Its the same plug for OBD1&2 and uses the same software etc (in most cases anyway).
The difference is with the ECU and the way it operates. Easiest way to tell the difference,
OBD-1 uses only 1 Lambda sensor, primary sensor before CAT.
OBD-2 uses 2 Lambda Sensors, 1 Primary sensor before the CAT which tells ecu how much oxygen is in the exhaust then another after the CAT. The sole purpose for the 2nd Lambda is ensure the CAT is working.
This is why you can have problems with a De Cat/Sports Cat with obd2 systems as the ECU picks up the CAT isnt doing its job properly.
Basically, Only on older cars will you get different plugs as there was an industry standard brought out to ensure any garage/person could access the ECU, hence the one plug for all makes.
HTH
Alan
Andy H
Re: OBD II Reader / Update
Post by Andy H » Thu Dec 31, 2009 6:18 pm
Well reader arrived today, and can connect with my other car [Focus 03], and daughters Focus 2000 1.8
Focus 2000 Error code P0171 Fuel system too lean. I have been changing ISV so their may be an air leak, or its sticking "open"
Tried the reader on the S1 160 Sport, reader connects up ok, but cannot communicate so EFI Euro 1 non SVA cannot be accessed.
Alan,
Thanks for the offer Ill see how I get on with the C/D supplied.
Andy
