Hi guys,
Does anyone know where i can find the details of older models, specifically i'm looking for all the technical and performance statistics for a 2007 Lotus Elise S.
Thanks in advance,
Woza.
Official Lotus Brochures
2010 Burnt Orange Evora
Re: Elise S
Hi Woza
You are welcome to a Pax in my 2008 Elise S at SIDC on Sat 27 March if you fancy a slow trip round Knockhill.
I run mine as a daily driver, and do the odd trackday. You should also be able to get a pax in an Elise R or Exige NA and a supercharged car to help you decide. If you have any questions ask away.
The car at Murrays looks good, both Graeme and Craig will look after you.
I found the following info
http://www.grouplotus.com/mediacentre/index.html
Search for Elise S
Search for Elise S
Lotus Elise S Technical Specifications
Lotus Elise S Specifications, Technical Details and Options
Vehicle Description Engine
Engine management Max Power Max Torque Power to weight ratio Specific power output Emissions control
Transmission Suspension
Chassis
Technical Specifications Mid-mounted, transverse, 1.8l, Toyota 1ZZ engine. Aluminium lightweight and compact construction, 4 cylinders in line, water cooled, naturally aspirated with double overhead camshafts, 4 valves per cylinder, rocker arms with low friction followers, multi-point sequential system fuel injection and electronic ignition. 1794cc Lotus T4e engine control unit (ECU) 100Kw (134bhp) @ 6200 rpm 172 Nm @ 4200 rpm 155 hp/ton 74.7 hp/l Three-way catalytic converter. Euro IV emissions compliant with full On-Board Diagnostics (OBD). C56 Gearbox, aluminium lightweight construction, 5-speed, constant mesh helical gears and open differential. Fully independent sport suspension utilising unequal length wishbones, Bilstein mono-tube gas damper, Eibach coaxial coil spring at each corner and front anti-roll bar. Lotus designed lightweight structure of epoxy bonded aluminium alloy extrusions with integral steel seat-belt support structure and lightweight steel rear subframe.
Steering Brakes
Wheels Tyres
Front
Gear ratios First
Solidly mounted mechanical rack and pinion steering box with 2.8 turns lock-to-lock. Servo-assisted, track tuned 4-channel Antilock Braking System (ABS) with Lotus/AP-Racing twin-piston fixed aluminium alloy front brake calipers, Brembo single-piston sliding rear calipers and 282 mm diameter, 26 mm thick front and rear cast-iron ventilated & cross-drilled discs. Lightweight cast 6 spoke wheels (5.5 x 16" front, 7.5 x 17" rear) Yokohama Advan Neova AD07 tyre LTS 175/50 R16 Rear Yokohama Advan Neova AD07 tyre LTS 225/45 R17 3.166
Second 1.904 Third 1.392 Fourth 1.031 Fifth 0.815 Reverse Final drive 4.312 Performance Figures
0-60 mile/h 0-100 km/h 0-100 mile/h ( )
0-160 km/h
Actual 5.8 6.1 17.4
Maximum speed
Fuel consumption - urban
127mph 205kph average 11.3 l/100km
Fuel consumption extraurban Fuel consumption combined 6.5 l/100km 8.3 l/100km
C02 emissions Weight distribution Fuel tank capacity Luggage capacity Dimensions Wheelbase Track - front Track - rear Overall length
196g/km combined (268g/km Urban, 154g/km Extra Urban)
43.5 (9.6 gal) 112 - 50 kg
2300 mm 1457 mm 1507 mm 3785 mm
Overall width (door mirrors 1719 mm excluded) Overall width (door mirrors 1850 mm included)
Overall height - midladen (as per unladen with 2x 75 kg occupants) 1117 mm
Overhang - front Overhang - rear Ground cleareance midladen (as per unladen with 2x 75 kg occupants) 783 mm 702 mm 130 mm
Vehicle mass - unladen (running order, full tank of fuel, no occupants, no luggage) 860Kg
08 Graphite Elise S
Re: Official Lotus Brochures
thanks wheelie - just put a deposit down on it, is the knockhill date an official track day or can i come down and spectate?
Trackdays are Trackdays, you can sign up to to go on with your car, or go out as a pax or second driver for free.
Anybody can come to the track and spectate for free.
