Squeaking Seal Between Roof and Clam
T6 KFR
Post by T6 KFR » Sat Apr 03, 2010 1:19 pm
well i have just collected my car from the bodyshop in aberdeen and they did a great job and very pleased : repaired rear clam spider crack and 2 x doors.
They removed the roof to allow access when respraying the rear clam and removing the engine cover. On driving home the P/S roof seal is squeaking very badly and in desperate in need of fixing.
Can anyone please help before i go crazy :|
cheers
Kevin
Gourlay83
Re: Squeaking Seal Between Roof and Clam
Post by Gourlay83 » Sat Apr 03, 2010 1:31 pm
Silicone Spray the Seals but best doing it with the roof off.
Spray up the seals then put the roof back on.
Alan
P.S Did you use Castle Park ?
T6 KFR
Post by T6 KFR » Sat Apr 03, 2010 2:20 pm
hey alan,
cheers i thought of doing that but was a bit worried the spray would eat away at the rubber...ill do that though!!
Yeh castlepark i went to, they have had the car 2 weeks due to needing new window seals and awaiting delivery on backorder from Lotus!
pleased with the finish and nice guys!
Gourlay83
Post by Gourlay83 » Sat Apr 03, 2010 2:48 pm
Shame they had the car so long, not so good.
My car will be going in shortly to get the rear clam repaired. Glad they're just up the road as I think my car will be in there more than once :oops:
Alan
Post by Gareth » Sun Apr 04, 2010 7:30 pm
Are these guys on email?
If so, what's the email address?
tia
G
jen
Girl racer
Post by jen » Sun Apr 04, 2010 8:31 pm
Gareth, they don't have a website or email, but they can be contacted on 01358 725852.
Jen
T6 KFR
Post by T6 KFR » Mon Apr 05, 2010 8:02 am
Gourlay83 wrote:Silicone Spray the Seals but best doing it with the roof off.
Alan
Well Alan i went out on my DIY sunday :) and bought some spray. Took the roof back off (firstly why have i never done that before in a nice day) and applied spray to seals against car and roof.
Guess what still F##king squeaking (maybe thats why i haven't removed the roof before) , only at P/S though. If i apply pressure internally the noise goes but i cant drive with one hand raised all the time :oops:
Ideas?
Gourlay83
Post by Gourlay83 » Mon Apr 05, 2010 8:58 am
Well, you tried Kevin.
Take it back to Castle Park, i'm sure they would sort it our for you. Even with you driving and Neil in the passanger seat.
Alan
Post by alicrozier » Mon Apr 05, 2010 10:29 am
Maybe the order you do up the fastners?
I've found it's best to do the fronts first (sides then centre) then the rear either side before doing up the middle rear. Just think it gets it centred properly and loaded the right way. Nip them first then go back around in the above order tightening properly...
T6 KFR
Post by T6 KFR » Mon Apr 05, 2010 12:30 pm
alicrozier wrote:Maybe the order you do up the fastners?
Spoke with Craig at MMC and he advised similar. So I popped down 1/2 hour ago , loosened all 4 bolts and the cross tightened them...havent taken it on the road yet but im praying its an improvement
T6 KFR
Post by T6 KFR » Mon Apr 05, 2010 7:37 pm
well drove home tonight and the constant squeak / creeking is still there :thumbsdown
so for the 5th time since Sunday i took the roof off again when i got home , lub'd it and re-tightened again.
I am really lost for ideas if it does the same tomorrow morning other than driving about without a roof!!!
Post by Mr Momo » Mon Apr 05, 2010 8:16 pm
Just remembered I used to use little felt pads - double-sided sticky stuff you can buy in places like John Lewis - applied in areas of most contact.
Emira - Volvo spec
T6 KFR
Post by T6 KFR » Tue Apr 06, 2010 8:08 am
Mr Momo wrote:Just remembered I used to use little felt pads - double-sided sticky stuff you can buy in places like John Lewis - applied in areas of most contact.
very good idea, i am round the bend...still squeaking this morning.
I will apply my arts and crafts skillset as the next option then.
Thanks for that , see if it works. I owe you MEGA if it does!
