S1 Cobra Alarm
S1 Cobra Alarm
Post by BiggestNizzy » Tue Apr 13, 2010 10:01 pm
I can't find my handbook, does anyone know the procedure for reprogramming the keyfobs.
Re: S1 Cobra Alarm
Post by Mikie711 » Tue Apr 13, 2010 10:31 pm
From the S1 owners manual.
1. With the alarm system disarmed and mobilised , switch on the ignition. Note that if the transmitter key codes have been wiped, the alarm must be disarmed using the touch key.
2. Insert the touch key into the receptacle on the steering column shroud. The alarm tell tale will light steady.
3. Press, simultaneously, both buttons on the new transmitter key for about ten seconds, until the tell tale in the key stops flashing and goes out. When the buttons are released, the key tell tale will light steady.
4. Press either one of the transmitter key buttons; the transmitter key tell tale will blink, and the alarm tell tale in the instrument pod will go out for one second.
5. Repeat 3 and 4 for all other transmitter keys to be used, up to a max of four. When all keys have been programmed, switch off the ignition (alarm tell tale will go out).
Note: this programming procedure erases all existing transmitter codes, so all keys to be used must be reprogrammed at the same time.
Re: S1 Cobra Alarm
Post by BiggestNizzy » Wed Apr 14, 2010 8:08 am
All programmed hopefully that will stop anyone breaking into it again.
Re: S1 Cobra Alarm
Post by BiggestNizzy » Fri Apr 16, 2010 1:12 pm
The alarm has gone off and is making some pretty weird noises, I am thinking either someone has been at it or it's broken, It took me a few attempts with the overide key to get it to disarm It will prime the fuel pump but not cramk so I am guessing the battery has gone.
Is there anything I can check
