Gaz Shockers
type36
Gaz Shockers
Post by type36 » Wed Apr 28, 2010 9:08 pm
Hi, I am going to ask a stupid question..... What way up do Gaz shockers go? The originals the body of the shock goes to the top. I would suspect that these Gaz shockers the body goes to the bottom. Am I right?
roadboy
Re: Gaz Shockers
Post by roadboy » Wed Apr 28, 2010 9:28 pm
Yes you are. They are twin tube so should not be mounted inverted.
Personally, I'd just box them up and send them back though as they're pretty useless IMHO.
HTH
Dan
SPS Automotive
Independent Lotus Specialists
type36
Re: Gaz Shockers
Post by type36 » Wed Apr 28, 2010 9:52 pm
If the Gaz shockers are useless what would you suggest I buy then?
Re: Gaz Shockers
Post by mckeann » Wed Apr 28, 2010 10:13 pm
ignore dan, its his time of the month :wink:
Gourlay83
Re: Gaz Shockers
Post by Gourlay83 » Wed Apr 28, 2010 10:24 pm
mckeann wrote:ignore dan, its his time of the month :wink:
and welcome to Scottish Elises.
Alan
Re: Gaz Shockers
Post by mckeann » Wed Apr 28, 2010 11:10 pm
gaz dont have a great reputation on elise forums, nitrons are the dogs bollocks. Wether 99% of elise drivers would notice the difference is debatable.
I do generally agree that you get what you pay for, but its the law of diminishing returns.
Martin Donelly has won races with gaz shocks. Fact is, donelly could probably win with spagetti suspending his car (unless i was racing him :wink:) but it cant be that sh*t.
Matelotman
Re: Gaz Shockers
Post by Matelotman » Thu Apr 29, 2010 9:10 am
I had GAZ shocks on my S1 (to replace original Konis) and found the fast road handling to be better than the billys that replaced them - took ages to get the damper settings right though. The only complaint I had with them that they were too hard for daily use and softening them made for comedy handling thats the only reason I got rid of them.
I had them on for over a year and had no mechanical issues with them either. :thumbsup
roadboy
Re: Gaz Shockers
Post by roadboy » Thu Apr 29, 2010 11:10 am
Ok, I'll clarify a bit.
Some of them seem to be fine but their quality control seems to be non-existant. I have seen dampers that are supposed to be the same where the valving in them is completely different, to the extent that you can feel it by hand. I guess they don't bother putting them on a damper dyno at all. I have also seen the same inconsistecy with their springs.
So really, it's pot luck whether you get a set of dampers that actually work or not. Personally I wouldn't want to spend 600 quid to take that kinda chance.
So there you go, perhaps the people who told you they're a decent damper can give you their direct experience of them now. ;)
With regards to what I would recommend, that would depend entirely on your use of the car and what tyres you run.
HTH
Dan
SPS Automotive
Re: Gaz Shockers
Post by mckeann » Thu Apr 29, 2010 11:38 am
dan, i've written 3 replies to your post, but none of them sound like i want them too. So i'll not bother arguing. Suffice to say, if the OP had started a thread asking what dampers to buy, i wouldnt have recomended gaz.
roadboy
Re: Gaz Shockers
Post by roadboy » Thu Apr 29, 2010 11:48 am
Fair enough Neil. Perhaps I could have phrased my initial post better. I just wrote it in a hurry.
Off to buy some Tampax now. ;)
Dan
SPS Automotive
MacK
Re: Gaz Shockers
Post by MacK » Thu Apr 29, 2010 5:15 pm
I considered buy some Gaz shocks, if I remember Brunty was selling them, but after reading various reports (mostly on SELOC) I decided against them and got Bilstiens again.
Gourlay83
Re: Gaz Shockers
Post by Gourlay83 » Thu Apr 29, 2010 10:49 pm
roadboy wrote:Fair enough Neil. Perhaps I could have phrased my initial post better. I just wrote it in a hurry.
Dan
He didn't ask what do you think of Gaz Shocks :roll: a simple question regarding fitting.
roadboy
Re: Gaz Shockers
Post by roadboy » Fri Apr 30, 2010 7:04 am
Dan
Which I answered! :roll:
Dan
SPS Automotive
