EMERALD / MAP
CALEYTRONIC
EMERALD / MAP
Post by CALEYTRONIC » Tue Jun 01, 2010 11:20 pm
HELLO JUST WONDERING IF ANYONE CAN TELL ME WHERE I CAN TAKE MY ELISE TO GET MAPPED I LIVE ON THE ISLAND OF LEWIS AND NO ONE UP HERE HAS AN ELISE NEVER MIND THE KNOW HOW TO GET MY EMERALD ECU UP AND RUNNING, SO IF YOU CAN TELL ANYWHERE IN SCOTLAND I CAN TAKE IT TO I WOULD BE WELL DELIGHTED :mrgreen:
Re: EMERALD / MAP
Post by Mikie711 » Wed Jun 02, 2010 12:33 am
:welcome Welcome to the forum Caley.
Couple of things first, typing a message with caps lock on is the same as shouting and most people don't like being shouted at so do us all a favour and type normally please :thumbsup . It's also customary to post up your first message in the newbies section, just to introduce yourself and say hello to everybody, have a look at the forum charter while your there which we encourage everybody to read.
As to your question, I had an emerald fitted to one of my cars and used Ricky Gauld at Huntly to map the car. He knows the Emerald system really well and would get you sorted out. To get you up and running you can contact Emerald themselves detailing the spec of your engine and they will send you (e-mail) a base map which once loaded will get the car at least running. Makes mapping much easier if you start from a base map rather than from scratch, also cheaper (less RR time).
What mods have you done to the engine out of interest and is your emerald an K3 or M3D?
CALEYTRONIC
Re: EMERALD / MAP
Post by CALEYTRONIC » Wed Jun 02, 2010 6:18 pm
:oops: sorry mikie
thanks for the info and i just want to say a big HELLO :thumbsup to everyone from all the people up here in stornoway and hope yer all having a nice day.
well mikie i've had my elise 2 years now and my engine.
bell & colville 160 upgrade
gas flowed cylinder head
updated valve springs
performance cam shafts
dual vernier cam pulleys
vhpd throttle bodies
m3d emerald ecu
magnex sports exhaust
and all going well i will have it back this weekend after getting a total respray, i saw it 2 days ago and it was looking amazing so i can't wait .
Re: EMERALD / MAP
Post by robin » Wed Jun 02, 2010 7:05 pm
Tut, do you have the map for the final N1TUT K-series engine? It sounds like it might be a reasonable place to start for this engine?
Re: EMERALD / MAP
Post by Mikie711 » Wed Jun 02, 2010 7:35 pm
Caley, what cams are in it, are they the original BP270's that came with the B&C 160 kit and are you running original injectors?
Mike
CALEYTRONIC
Re: EMERALD / MAP
Post by CALEYTRONIC » Wed Jun 02, 2010 8:42 pm
thanks robin & mikie
i've just sent a email to emerald for a base map because i don't have any maps at all, and the cams are the one's that b&c fitted.
the car has the cream injectors i think that is standard, so any advice you can give me is all good i don't know anyone who has any idea about the lotus elise.
Re: EMERALD / MAP
Post by Mikie711 » Wed Jun 02, 2010 10:21 pm
I've got the full map from my B&C 160 although it never ran TB's the rest was the same should be close enough to get you started. Give me a shout if you want a copy. Having said that not sure it'll work because I had a K3 and I see yours is a M3D. You could check with Emerald and see if it's upgradable, serial number 41272 or higher. Worth doing IMHO, the newer software is much better.
CALEYTRONIC
Re: EMERALD / MAP
Post by CALEYTRONIC » Wed Jun 02, 2010 10:33 pm
Excelent if i don't get a reply from emerald by the weekend i take you up on that .
thanks mikie
Re: EMERALD / MAP
Post by tut » Thu Jun 03, 2010 9:33 am
Yes Robin, still have it and it looks as if it would suit his car pretty well. I think the B&C 160 had the cams changed, but not as aggressive as my 285H, then 285M, but it would certainly be worth trying the two maps. First one was done by Ricky, then I went down to Dave Walkers, spent quite a bit of time on the R/R, and the difference was 1 hp.
Don't know your name Caley, but let me know if you would like me to e-mail them to you.
CALEYTRONIC
Re: EMERALD / MAP
Post by CALEYTRONIC » Thu Jun 03, 2010 10:47 pm
Excelent thanks again, just in the door ive been working on the car all day, got it back from the spray shop this morning and it's looking A1 well delighted!
just wish it ran as good as it looks so if you got a map you think i can use then please sent it on because emerald have not been in touch yet and i need to do something.
Re: EMERALD / MAP
Post by Mikie711 » Thu Jun 03, 2010 11:00 pm
Caley, PM tut with your e-mail address as it sounds like his will work as his ECU was an M3D. Try phoning Emerald, always found they were quite slow to reply to e-mails.
tut, if you changed the cams and didn't go to 285's what did you change them for as the B&C 160 has 270's in it.
Re: EMERALD / MAP
Post by mwmackenzie » Thu Jun 03, 2010 11:15 pm
Hi and :welcome Caley! I'm also from Lewis, Knock, Point to be exact. Sorry I can't be of any help as I don't use an emerald, just a std mems on mine.
Good to see another Lewisach on here! :thumbsup
Mark :cheers
Re: EMERALD / MAP
Post by tut » Fri Jun 04, 2010 4:21 am
I did change the cams for 285's Mike, H in the first N1, M in the present one.
CALEYTRONIC
Re: EMERALD / MAP
Post by CALEYTRONIC » Fri Jun 04, 2010 10:07 am
Email address is mmpwcal@aol.com
i will give emerald a phone when i get to work and i will let you know what they say later on mike.
Thanks mark for the hello :cheers i know a lot of people from your neck of the woods so speak later.
Everyone have a good FRIDAY!
caley
Re: EMERALD / MAP
Post by tut » Fri Jun 04, 2010 11:49 am
Caley, I have sent you three maps to try. They are all similar, but it is seven years ago now so can not remember or check them against each other.
Mail them onto Mikie and he will be able to have a look at them as well, and compare them to his own.
