Racknpinions sought...
Post by campbell » Thu Jun 03, 2010 12:02 am
I've got a new noise.
It's been a while since one of these came along.
It goes a little something like this...
Once car is nicely warmed, at standstill or low speeds, an eighth or quarter turn of the steering wheel either direction from dead ahead, produces a light squeaking/creaking sound from somewhere down the steering column. Very akin to the creak you get off S1 door hinges that are in need of a bit of graphite lube.
I'm thinking something at the steering rack (accessible...not...) - best case is needing some grease, worst case is worn and needing refurb/replacement.
Discuss?
thanks!
Campbell
Re: Racknpinions sought...
Post by robin » Thu Jun 03, 2010 7:22 am
I would guess anti roll bar bushes.
Can be lubricated or replaced - on a car of this vintage, I might be inclined to replace - EP sell these in a number of variations - but you should buy the OE ones for your use - either from EP or Lotus, whichever is cheaper.
Post by campbell » Thu Jun 03, 2010 8:09 am
Thanks Robin.
That was a job I was going to tackle last summer, had lined up Fergus' rivnut gun thingy for fixing the inevitably minced undertray fixings, then never got round to it :-(
Post by BiggestNizzy » Fri Jun 04, 2010 10:43 am
DOing this now it's a pig :(
Post by campbell » Fri Jun 04, 2010 1:32 pm
My understanding is that the nasty bit is the animalising-out of original fixings for front undertray, and the re-fitting of fresh rivnuts afterwards.
I believe there is a neat tool can do the replacement of the fixings, but can't profess to be experienced or qualified in its use!
I think I will have to entrust this one to a professional.
Campbell
Post by BiggestNizzy » Fri Jun 04, 2010 1:43 pm
The rivnuts where already mangled in mine so that wasn't a problem, although I will have to source a rivnut tool and some rivnuts.
Access is the big problem getting in to loosen the screws was a pain. the antiroll bar had swelled with rust around where the old rubber bushes where so I had to buff that away to get the nylatron ones to fit. but the single biggest pain is fitting it back on I just cannot get one of the bolts in I was at it to 11:30 last night and when I finish work in 10 mins i am off to take another crack at it.
Post by campbell » Fri Jun 04, 2010 2:20 pm
Should I be buying a fresh ARB as well then?
Post by BiggestNizzy » Fri Jun 04, 2010 2:22 pm
No, you can polish it up to remove any blistering rush a roll of emery cloth a file and a vice to hold it in should do
Post by campbell » Fri Jun 04, 2010 2:32 pm
ta
Post by BiggestNizzy » Fri Jun 04, 2010 8:16 pm
job done.
Post by campbell » Sun Jun 06, 2010 12:16 pm
bravo!
Post by BiggestNizzy » Sun Jun 06, 2010 1:13 pm
It hasn't stopped the noise I was hoping it would so the bottom A arm is coming off to check evrything is ok.
put the top screws in first only 2 or 3 threads then the bottoms in 2 or 3 threads and work your way round a few threadsa t a time.
is going to be a pain if you have std wishbone bushes as access is a pita.
Post by campbell » Sun Jun 06, 2010 5:59 pm
what year is your car?
Post by BiggestNizzy » Sun Jun 06, 2010 7:58 pm
1997
Post by campbell » Sun Jun 06, 2010 11:26 pm
I might have read somewhere that changing the ARB mounts on pre-99 cars is different / trickier than 99 onwards. But then again I could be mistaken!
Well done for completing the job all the same. Good luck with the rattle-trapping. I know the feeling...
Campbell
