leaky side windows
dirkpitt
leaky side windows
Post by dirkpitt » Thu Jul 22, 2010 1:09 pm
hi,
anyone have an issue with leaking door windows?.......i have noticed that the top edge of the window leaks in the rain.........is this common and is it fixable?..thanks
leigh
1998 Audi Elige s1-1.8t 20v
Re: leaky side windows
Post by Shug » Thu Jul 22, 2010 1:31 pm
Hi Leigh,
Always worth pointing out what kind of car it is :) From your avatar, I'm guessing S2 Exige. There are adjustment screws in the door to line the windows up, but being an S2, that's as far as my knowledge goes on that - will let one who's done it fill you in further.
Post by kenny » Thu Jul 22, 2010 1:36 pm
They all do that, well most Exige hardtops do anyway.
dirkpitt
Post by dirkpitt » Thu Jul 22, 2010 1:46 pm
lol....yeah soz forgot to mention which model.....yeah its an exige s2
ill look into the screw adjusting advice, thanks.....
kenny,
yeah i was afraid that would be the case with these cars, but thought it would be worth an ask to see if it was so, thanks
Shug wrote:Hi Leigh,
woza
Post by woza » Thu Jul 22, 2010 4:45 pm
yep - they all do that - part of the fun!
2010 Burnt Orange Evora
Post by mwmackenzie » Thu Jul 22, 2010 6:52 pm
There are adjustment screws inside the door, if your stuck you could try SLS http://www.scottishlotusspecialists.co. ... ences.html
Post by tut » Thu Jul 22, 2010 7:10 pm
'96 S1, does not leak a drop.
Stewart
Post by Stewart » Thu Jul 22, 2010 7:12 pm
No leaks here - 06 S2 Exige. I would think that a wee bit adjustment may help.
Stewart
dirkpitt
Post by dirkpitt » Sun Jul 25, 2010 12:44 am
ok an update on the leaky window..
shug....done what you said and took a ganda on the SELOC site and typed in window adjust and bobs your ungle, there it was. two screws points adjust for the tilt and a bump adjust on the inside of the door cover, for the height.
so , i got cracking the other day on one door and adjusted. all i need now is a bit of rain :? to see if im successful and QED! :D
leigh
Edin430
Post by Edin430 » Sun Jul 25, 2010 1:22 pm
bucket of water?
i did the same and it solved the problem :thumbsup
dirkpitt
Post by dirkpitt » Mon Jul 26, 2010 9:12 am
lol.......no need for a bucket of water, with the way the weathers going :(
