Mr Haynes shows the above with holes in it to allow a tool to be inserted when undoing the centre tight bolt.
My pully does not have any holes to help.
Any good sugestions ?
Andy H
NLC / Crankshaft Pully 1.6 Zetec
Re: NLC / Crankshaft Pully 1.6 Zetec
Air gun is the easiest but if thats not an option see if you can access the flywheel and hold it with a suitable bar, be careful when removing the pulley as the cambelt drivegear is not keyed onto the crankshaft !
