Aaaah, complex answer.
The Janspeed you’re talking about was standard in the Exige/340R, and it is made for an engine with power characteristics slightly different than the stock 120BHP S1, it shifts the power higher up in the RPM range at the expense of some low end (VHPD’s have less low end torque than the 120BHP Elise).
So it would be great if you can use that additional breathing capability, like if you have the 165 BHP PTP kit installed or at least a modified head, a bigger throttle body, some sort of better induction filter, etc.
When I sold mine (to a fellow SE’er, but can’t remember the name) he mentioned he was very happy with the power characteristics. Basically worth it if you like trackdays, as it will shift power up anyway.
Now, I changed it for an EBD ultrabore stepped 4-2-1, and it gave some improvements, again at the expense of midrange.
The EBD was supposed to be the best of the best, but then I changed to a 2bular, which has been much better and the one I’m keeping for good.
Check the power curves with those three compared:
